Removing/altering the CE (octopus) on a 400 with 426(?) head
7 replies to this topic
  • nnamssorxela
Posted November 12, 2009 - 10:55 AM
I was having a little trouble jetting my wr400 with a yz or wr 426 head. I posted in the jetting section and eddie said that I need to alter the CE setup also known as the octopus that the stock wr400 carb (flat fcr)/head utilize. I couldn't find anything that described this modification and I'm beginning to wonder if I do indeed have a 426 head/top end, or if it is all stock wr400 stuff.
I feel silly asking, but is there an easy way to determine what head I have? I tried to search, but all I found was a great deal of threads asking about and explaining the differences between the two motors, not how to distinguish them. I suppose once I figure out what I have, I'll then move on to altering the "CE."
Thanks,
-Alex
I'll post pictures of carb and head if needed, as they are both off of the bike at the moment.
  • Flooder305
Posted November 12, 2009 - 04:12 PM
Post 'em, can't hurt.
  • umu24013
Posted November 13, 2009 - 12:29 AM
Look for a number stamped just below the intake port on the head
5JG00 - you have a YZ/WR 426 head
5BE00 - you have a YZ/WR 400 head
  • GCannon
Posted November 13, 2009 - 11:33 AM
Isn't there a vacuum port near the intake manifold that is not there on the 426 head since the hot start is internal in the newer fcr carburetor used on the 426?
  • Parx_400
Posted November 13, 2009 - 04:02 PM
Well what did they do for the 2000 wr400? It had the new carb but was still a 400.
  • nnamssorxela
Posted November 14, 2009 - 01:54 PM
pictures!
umu, according to what you posted, I still have the 400 head.
gcannon, looks like there is indeed the vac line, so again, I'm thinking 400.
parx, the head is either from a 1998 wr400 or a 2002 426. basically the only difference I know if is the hot start line, and the valves being stainless on the older 400 and ti on the 426. Is that the only differences? I'm so confused.
  • Birdy426
Posted November 15, 2009 - 11:42 PM
Yup...all 400 parts...
  • nnamssorxela
Posted November 16, 2009 - 04:58 AM
Thanks, that's what I figured.
