TPS - is it worth fixing?
8 replies to this topic
  • Adammoto
Posted November 12, 2009 - 09:10 AM
I have spent a lot of time in the garage already trying to figure this out. Will someone who has been though the TPS problem before please point me in this right direction?
Disconnecting the TPS significantly reduces a rough running condition at 1/8 to 1/2 throttle or so under light loads on my 09 YZ450F. The question is what to do about it. I prefer the feel of the motor with the TPS connected, but fixing it sounds like a major PITA. From what I have been reading, people approach the faulty TPS from a number of angles. Do I need to adjust the TPS, buy a new TPS, replace the CDI, or all of the above?
Here are the resistance measurements I took last night:
Resistance blue-black (static): 4,220 Ohms (within spec)
Resistance black-yellow (dynamic): 500 closed, 3.66 open Ohms (not quite within spec).
If this is a wild goose chase I'd rather just live with it. Thanks for any help on this one!!
Posted November 12, 2009 - 09:31 AM
At 3660 Ω, you're pretty close, and your problem may be a simple adjustment.
You might first see if heat significantly changes the readings you get. It shouldn't change by more than 5% at operating temps.
After you have verified the resistance readings are stable and consistent, do the adjustment check on 6-6 - 6-7 of the manual (sensor output voltage while running at idle). It may be out of spec, and that could correct the problem.
IF it needs to be adjusted, loosen the mounting screw enough to allow the TPS to be pivoted on its mount while running by tapping on the mounting flange (prudently) with a small punch. This will make it much easier to dial in, and cut the number of times you'll need the carb on and off.
  • Ga426owner
Posted November 12, 2009 - 09:50 AM
agree try to adjust the TPS position first, but only after you notch the stock (from Factory)position on the carb body and the tps sensor. You will need to know the exact stock position if it all goes to heck and a handbasket...
The changing the TPS Sensor position may possibly adversely affect the static (within spec)reading to get the dynamic into spec. You will only make the slightest movements of the TPS from each side, left or right of the notches and get the settings each side with the meter.
If you can not get both within spec - my assumption, Grey correct me, is that the TPS will need to be replaced.
Posted November 12, 2009 - 10:11 AM
The changing the TPS Sensor position may possibly adversely affect the static (within spec)reading to get the dynamic into spec. ...
I'd say that, yes. Also, in reading the resistance between open and closed, run the sensor through its whole range slowly and watch for any sudden dips or spikes in resistance, which would indicate faulty spots on the sensor track.
  • Adammoto
Posted November 12, 2009 - 10:28 AM
Do you mean watch for spikes in resistance when rotating the throttle or when rotating the TPS with the throttle closed?
I'll try that and the sensor output voltage test tonight...then take stab at adjusting it if necessary.
Thanks for the reponses.
Posted November 12, 2009 - 10:37 AM
If you have the sensor in your hand, then rotate it by hand. If it's on the carb, just run the throttle through its full range as you read the resistance.
  • Adammoto
Posted November 12, 2009 - 04:19 PM
I did the output voltage test and got .76 volts (the upper spec is .78). Also did the dynamic test looking for spike in resistance and it appears to be operating smoothly. So basically the thing is working right aside from slightly low resistance at full throttle. Now I am even more confused...I thought I had it diagnosed. Any suggestions?
Posted November 12, 2009 - 04:29 PM
If you feel like experimenting, advance the TPS slightly toward the lower limit of output. See if the upper and lower resistance limits can be brought into spec without going lower than minimum output voltage. Then see how it runs.
You may have a problem that a needle with a differeny upper diameter may cure.
  • Adammoto
Posted November 12, 2009 - 04:38 PM
I tried the NFLQ needle (richer straight diameter) and didn't notice a difference. I'm at 5,000 ft. in Colorado so the richer needle seemed strange, but others had success with the NFPP. Anyway no noticeable improvement for me.
Guess I'll try experimenting with the output voltage.
