I'm rebuilding my 02 cr250. I thought I'd replace the right side crank seal while I have her torn down. It was puking a lot of spooge and was using up some gear oil. My question is should I replace the collar as well as the seal? It looked like some oil was getting past the seal but I couldn't really find anything wrong other than the collar look like it might of had some wear. I couldn't find any specs on the I.D. of the collar. There are some wear lines from the oil seal. You can't feel them just see them.
Right side crank seal replacement question.
Started by Sticky Throttle, Nov 07 2009 09:56 PM
3 replies to this topic
Posted 07 November 2009 - 09:56 PM
Posted 08 November 2009 - 07:50 AM
Its usually the main bearing being loose and leting the crank wobble and suck in the oil. Check the main bearing for up and down play. There should be zero play.
Posted 08 November 2009 - 11:20 AM
I check that at the connecting rod and the crankshaft. I couldn't feel any play at all, they both felt tight.
