What to lube a clutch lever with?
5 replies to this topic
  • sam351
Posted 07 November 2009 - 03:29 PM
Is there such a thing as "clutch lube"? If not what do you guys use? A friend told me I should lube my clutch since it was being all stiff... so yeah... but actually I found out that is was because it was screwed on too tight.. but I still wanna lube it. this is for the lever and whatnot...
  • schrode
Posted 07 November 2009 - 03:37 PM
standard cable lube for the cable. spray a little then work the cable a bit and repeat until a little drips out the engine end of the cable. put a little grease on the pivot bolt on reassembly. good to go.
  • txmxer
Posted 07 November 2009 - 03:42 PM
cable lube for the cable (I think its a silicon spray or something), and for the actual lever part I cleaned mine out with wd 40 cause it had dirt in there, then I put some maxima grease I had laying around but any kind will do.
  • Mike38
Posted 07 November 2009 - 05:51 PM
If you mean the pivot point (shoulder bolt) I use a gun grease called Gunslick. It's a graphite grease, and seems to work good for me.
  • samras121
Posted 07 November 2009 - 08:30 PM
there is a tool u put over top the cable and put a spray cans red nozzle tip into it. white grease is best.
  • lumpy790
Posted 08 November 2009 - 07:52 AM
Some use special cable lube oil and some with teflon. I use WD40 and inject it with the clamp on luber available from your local dealer for $5 or $6 bucks..
