I have a bit of an issue with my xr650r, it won't rev out to the limiter. It feels like it hits a "limiter" at about 6800 or so at fulll throttle. With less load (4th gear and 3/4 throttle) it will rev to the limiter but not smoothly. Jetting is good (bigger/smaller main has no effect), coil is new, plug and boot are also new. Checked the exciter coil voltage at the cdi (around 145v at the cdi plug), and at the coil (around 75v, so less than the minimum 100v specified by the manual). The low voltage at the coil could be the issue so i checked the loom thoroughly but cannot find any issues.
Another thing, the manual specifies at least 0.7v from the pulse generator when kicking but i'm getting 6-7 volts, ie. more than 10 times more than the specified minimum. I suspected that there might be voltage coming off one of the lighting coil outputs due to a short between the wired in the loom but the wires all check out fine on the multimeter, no shorts.
I started the bike and with it running, measured the output into the coil (meant to be at least 100v at kicking speed) and found that at idle it's around 110v but as i rev the motor it drops off. What on earth could be causing these issues? Testing with 2 different cdi's has no effect on the results and the motor still stops revving at around the same point. Earths are all good.
All of the peak voltage tests are performed using a peak voltage adapter. Measured resistance of the pulse generator is 250ohms and the exciter coil is about 90ohms (hot values). There are no honda values for resistance as far as i can acertain.
All suggestions welcome.
