PeterJ said:
Sorry to hear about your situation Blaster. Did you have an MRI? I'm no doctor but I have had surgery on both knees and have low to moderate degeneration in the L5-S1. I can't imagine how painful it must be to actually rupture a disk. The pain gets so bad for me at times that I can't even stand on my feet. Everything I have heard is to avoid steroid shots to the back. I've been told they cause things to stiffen up. That would be fine if I was 80 years old and the most physical thing I wanted to do was go grocery shopping. I'm afraid I would really hurt myself if I went the steroid route. I'm going in for a PRP treatment on Tuesday.
The PRP, so I've been told, will dramatically increase the amount of pain for the short term, but will cause the troubled area to heal itself. Considering I have had a spasm problem that surfaces about once every 6-12 months for about 25 years, I am looking forward to a cure.
I wish you well.
You are correct, the pain is very intense, and does not let up. I have had several knee surgeries including an ACL replacement. So I have had some exposure to pain. In the past, I have always opted to not take the prescribed pain killers. However, with the ruptured disk, I can not be as caviler. I take as many as I need to survive the pain. Sometimes doing a vodka shooter with them.
As for the MRI, I have had one, it clearly shows the rupture at L5-S1. The epidural shot of steroid was explained to me with no mention of any negative side effect at all. I will have to find out more, obviously, however being stiff is not exactly the worst side effect I can imagine. It was presented to me as as a very very strong pain killer that loiters around in the injection site doing it's job for quite some time. Thus giving the receiver an immediate relief from the pain.
What is a PRP?
Blaster
Found it...... sounds interesting.
Platelet-rich plasma: Does it work?
New study reports on the platelet-rich plasma treatment and its use in sports medicine; cautions more investigation needed
ROSEMONT, Ill. – Platelet -rich plasma (PRP) is currently used as an alternative treatment method for several common orthopaedic-related sports medicine conditions. According to a new study in the October issue of the
Journal of the American Academy of Orthopaedic Surgeons (JAAOS), early outcomes of PRP appear promising; however, larger clinical studies are still needed to determine the benefits of its use.
"Some believe that PRP may catalyze the body's
repair mechanisms at areas of injury, improve healing and shorten recovery time," said study co-author Michael Hall, MD, a senior orthopaedic surgery resident at the NYU Hospital for Joint Diseases in New York. "However, there currently is minimal evidence of this clinically and more research must be performed."
A Simple Process and Procedure
- Obtaining and utilizing PRP is a relatively simple process: a patient's own blood is placed into a centrifuge that rotates at high speed.
- This procedure separates the red blood cells from the platelets, which are blood cells that release growth factors that help the body heal itself.
- Next, the physician takes the platelet-rich portion of this blood (PRP) and injects it directly into the patient's injured area and the treatment is complete.
PRP Used Primarily for Chronic Conditions
PRP treatments have been used for the past two decades to improve wound healing and bone grafting procedures by plastic and maxillofacial (mouth, jaw and neck) surgeons. It is only in recent years that orthopaedic surgeons and sports medicine specialists have utilized this technology.
PRP use in sports medicine primarily has been for the treatment of chronic tendon conditions, but also for acute muscle injuries and for the augmentation of tendon repair in the operating room.
The most common applications include:
- tennis elbow (lateral epicondylitis);
- Achilles tendonitis (inflammation and swelling of the Achilles tendon);
- patellar tendonitis (inflammation of the patellar tendon, also called "Jumper's Knee"); and
- rotator cuff tendonopathy.
