So my girlfriend has a YZ125 that I've been working on getting jetted properly because back when she started riding with me a few months ago, it was running so rich it'd cover the swingarm in goo and foul a plug in about an hour. Granted, she's a little timid on the bike. (obviously not the best choice in bike for her to buy, but she got it before I met her) But, I also know from experience from riding my Gas Gas 200 that if a 2 stroke is jetted right, you can bog it without fouling. So, I read the big awesome sticky about jetting 2 strokes, but I have a gremlin remaining.
I got the pilot tuned in, but then ran into trouble with the needle. The way it was set up, it was lean on the top end of the needle's responsibility, so I lowered the clip (down one notch from where it had been, to the last notch) and fixed that problem, and then moved on to get the main set right. But, after all was said and done, a problem that had been there before in the performance was still there. The bike runs pretty rough with small throttle openings. Doesn't matter what RPM you're at, it's pretty sputtery if you open the throttle less than half. Full throttle is awesome. Doesn't change whether the bike's warm or cold.
So, do I need a new needle, or am I still too rich on my pilot circuit? Since I don't have the bike right here with me now, I can't look at which needle it has, and I'm not looking for y'all to tell me exactly what I need, I'd like to think I'm smart enough to figure that out, I'm just wondering generally what y'all think needs to be changed, and in what direction. As in if I need a new needle, what am I generally looking for. (ie longer, fatter, etc...)
FWIW, I'll give my conditions:
99 YZ125
4200' elevation, temps around 50-60 this time of year
FMF fatty pipe, FMF powercore silencer
Down to a 330 main and 45 pilot
Thanks!
