Bottom end gaskets
6 replies to this topic
  • brianandmell
Posted 03 November 2009 - 06:25 PM
I have a question, I am doing a bottom end and a top end on my sons bike. I have all the top end gaskets already. I am wondering about the bottom end. Moose sells a whole kits with oil seals but I am not sure of them. Do I really need all the oil seals or should I just get oem gaskets.
Plz any sugestions, I am driving myself crazy..... bike is a 03 KX 125.
  • 99Kawi_KX250
Posted 03 November 2009 - 06:47 PM
IMO....If your doing the top and bottom end, Bearings, Crank ect....I would replace all the oil seals as well, that way you won't have to worry about having to go back into it for a while.
  • Jeekinz
Posted 04 November 2009 - 04:00 AM
Yes, you're better off replacing all the seals now. You will also need a tube of case sealer like Yamabond for the case halves. You can't use silicone.
  • brianandmell
Posted 04 November 2009 - 06:10 AM
Thanks, So the onlyother thing I would like to know is. I have a cometic gaskets for the top end and I would rather use those. But for the bottom end the only kit i can
find with all gaskets and oil seals is Moose, are those ok for the bottom end?
  • A_Vasiliev
Posted 04 November 2009 - 06:15 AM
It'll be fine.
  • Jeekinz
Posted 04 November 2009 - 06:47 AM
I'm pretty sure Moose just rebranded those gaskets. They should be fine.
  • hi_im_sean
Posted 04 November 2009 - 07:59 AM
the moose and msr kits both rebrand stuff. nkm?, ntm? whoever they are, makes the dam parts. i think commetic and athena rebrand someone elses seals and make their own gaskets
