is cam2 purple 50/50 with pump gas about that same as vp u4.2 except the oxidation
Cam2
Started by samras121, Nov 03 2009 06:17 PM
11 replies to this topic
Posted 03 November 2009 - 06:17 PM
Posted 04 November 2009 - 04:00 PM
i know its not the same, but is it anywhere close? or is there any other combination of fuel or a different fuel that will be fine on the motor and not as expensive?
Posted 06 November 2009 - 08:39 AM
i talked to the guy that built it and he said it had to be vp u4.2. but its expensive. i have to run it because of the lead and oxygenation. i was told i cold get away with no oxygenation but would be best to have leaded fuel. i asked about high octane aviation fuel and he flipped out. but if it comes down to it ill just have to knuckle up and stick with the u4
Posted 07 November 2009 - 07:27 AM
its a 2007 crf250r. high compression piston and head work done by pr2. im still trying to figure out what work was done.
Posted 07 November 2009 - 07:53 AM
if you dont want to run u4.2 than i would like at the streetblaze100.it is unleaded however.
Posted 07 November 2009 - 03:05 PM
Tetra ethyl lead(TEL) was added to pump gasoline in the past for two reasons. First, it is a very effective octane improver. Second, it "padded" the valve-to-seat interface to retard valve recession. Prior to the unleaded fuel age, most all-iron engines had the seats cut right into the head. They would eventually get hammered out when running unleaded. When lead was phased out, manufacturers began installing hard seats or induction hardening the integral seats.
Those are the good things about TEL. The bad is that it is responsible for more engine deposits and leaves toxic lead everywhere between the chamber and exhaust tip.
