Cycra Handgaurds
3 replies to this topic
  • FNG241_WR450F
Posted April 23, 2003 - 06:01 AM
Wanted to see if anyone had tried mounting cycra handgaurds on their 450? How difficult was the install and did you use the triple clamp mount? Any help is appreciated.
Thanks!
  • ralphfurley
Posted April 24, 2003 - 03:53 AM
on my wr450 I put on
Moose Fat bars (cr low rise)
Universal adaptor
Cycra handguards - triple clamp mount.
1. you will need new triple clamp bolts
10 mm longer than stock to allow for the thickness
of the cycra adaptors
2. Clutch side
you will have to move the brake line/headlight
bracket to the inside and bend the retainer tab to clear
the new cycra bracket
3. Throttle side - good fit using new longer bolts
The light switch bracket does not fit well on the FAT bars, I will have to fix that.
overall it went together well with a minimum of grunt
  • FNG241_WR450F
Posted April 24, 2003 - 04:39 AM
Thanks for the info. Did Cycra supply the longer bolts?
  • ralphfurley
Posted April 24, 2003 - 05:26 AM
No.
Pep Boy 50 cents x 4
