1 reply to this topic
  • Hissi
Posted April 23, 2003 - 04:37 AM
I am new here in this forum sorry about my bad english but I am from Austria! My WR does not work because the bearing which is near sprocket drive 14T (called in the Microfiche) is damaged! The Bearing has the number 24 93306-20593-00 in the microfiche is it possible to change this bearing without divide the engine in his parts?
Bye :)
  • new2blu
Posted April 23, 2003 - 05:07 PM
In my owner's service manual(USA edition) on page 4-97 look at the lower illustration. The rear shaft is where the front sprocket mounts there is a plate that is oval shaped that holds the bearing in. Im not sure if the bearing would be loose enough to be pulled out from the outside. Probably have to split the case :) ---but you could try to remove it from the outside it would be much easier.
