yamaha 426 headwork, jetting, and funny idle, pilot test unresponsive
7 replies to this topic
  • nnamssorxela
Posted 02 November 2009 - 10:33 AM
Ok, so let me start by saying that carbs blow my mind. I understand the general principals, but this not not enough to get the job done.
To start:
1)1998 Yamaha wr400 with a 2002 yamaha 426 top end and I believe the wr400 carb.
2) 0ft elevation currently, soon to be 725-1000ft. Temps in the 70's, high humidity normally 60-100%, spirited street riding, some offroad.
3) Full Yoshimura RS3 exhaust, airbox lid removed, '02 426 top end as mentioned earlier. Thinking of adding airbox vents in the near future after everything else is sorted.
4) Stock Jetting: Starter jet 65, 42 or 45? pilot jet, 162 main jet. (from research)
Current Jetting: 82 starter jet, 45 pilot jet, 170 main jet.
5) From what I can remember (it's been so long ago) the bike ran fine. There was a slight pop on deceleration, so I thought I would richen it a tad (never touched the jetting as the bike was new to me). The second I touched it it went to hell. popping like crazy, running rough. Couldn't get it started. Long story short, when I adjusted the fuel screw (zip-ty racing), the rubber o-ring broke in half and lodged itself up there. I got a replacement spring, o-ring, and washer, threw in a new spark plug, and it essentially started right up. In attempts to confirm the pilot circuit, I found adjusting the fuel screw had no affect from almost shut to all the way open (bike warmed up etc). I also noticed that when I came to a stop, the idle was way high (3500rpms or so). If I slowly released the clutch as if I was attempting to stall the bike, as soon as the clutch caught (and I then pulled it back in), it would return the bike to normal 1500rpm idle that is at when idling warmed up. Getting fed up, I took it to a shop who said that my pilot was too lean.
6) When starting, I pull the choke, start the bike, and let it warm up briefly while choked and idling high(10 secs), then I press the choke in while I gear up and let the bike idle at it's normal 1500rmps. I try not to leave until it reaches at least 125 degrees as indicated by my temp gauge. Once running at low RPMs, when I pull the clutch it will return to 1500 rpms. Once I run the bike above 3500rpms to redline the idle will return to 3500 or so until I bring it down by dragging the clutch, which is annoying at stop lights as I have a loud pipe and people look at me funny. As far as I can tell, once the bike warms up (140-180F) the problem is a little worse.
I haven't ridden the bike much since I owned it, and there was supposedly less than 2 hrs on the new 426 head, but it was killer noisy when I did ride. Checked the valves and they were embarrassingly waaay tight. Having the head redone with SS valves, new springs etc, and seats re-cut. When I install that, a new air filter will be going in as well.
Should I wait until I re-install head and air filter before I mess with the jetting? I'm afraid of running way to lean and risking damage to my new head. Talked to someone with a similar build and he says he is running a 50 or 55 pilot. I know I should only do one thing at a time as there are so many factors that can affect the way the bike runs, but since I have the bike apart I want to get as much done as possible.
Thanks for any and all wisdom you can bestow upon me.
-Alex
EDIT: And the air jet (?) on the right side just above the fuel line and below the phillips head screw on the right is a 90.
  • Eddie Sisneros
Posted 02 November 2009 - 06:50 PM
you need to get rid of the CE (the octupus).
remove and connect the left over nipple on the carb together with a short left over hose.cap the vacuum source at the cylinder head.
then confirm the pilot jet is clean and that it is a 45 or 48. make sure that the slide plate is square end down.
set the fuel screw at 2 turns.
report back.
  • nnamssorxela
Posted 03 November 2009 - 04:39 AM
Thanks for the help! As soon as I get the head back and installed, I'll remove the CE. I assume there are a couple diagrams that show what to do, so I'll source one of those.
The pilot jet is indeed a 45 and it does look clean and normal. Should I be putting something on these threads to prevent them from seizing?
Appreciate the help,
-Alex
  • nnamssorxela
Posted 10 November 2009 - 05:48 AM
Just got the head back.
Still stumped on removing the CE. Is this only something you do when you have a 426 "head" with a wr400 carb? I'm pretty certain that the carb is the earlier FCR that came on the wr400, but how do I tell what head I have?
  • nnamssorxela
Posted 15 November 2009 - 07:26 AM
So it turns out I have the stock wr400 head, so I'm assuming the entire bike is the stock wr400.
I just purchased a new filter and will be installing that along with the head and seeing where it stands as far as running condition.
If it appears that the pilot is still lean (as it appeared before), I'll attempt to richen it via one of the 300 or so knobs, screw, and adjustments on the carb (is there a pilot fuel screw?). Or, I'll try out the 52 pilot jet that I just picked up.
Any other suggestions?
Thanks,
-Alex
  • Eddie Sisneros
Posted 15 November 2009 - 03:28 PM
52 pilot jet is way too big.
  • nnamssorxela
Posted 16 November 2009 - 04:56 AM
What size would you recommend?
  • Eddie Sisneros
Posted 16 November 2009 - 06:32 AM
48 max.
did you do what described with the CE? ever had the slide out of the carb?
If you enjoyed reading about "" here in the ThumperTalk archive\, you\'ll LOVE our community. Come join ThumperTalk today!
