Many of you have been following my progress on my subframe and plastics swap from 1998 style to 2001+ RM250.
The step by step link:
http://www.thumperta...ad.php?t=825826
I think I'm the first to do this swap on this model/year(s) bike. I want to thank Cammeddr-z for help and some pics on his previous swaps... Plus, for kinda giving me the confidence to try it myself!!
I knew if I wanted the new style RM250 plastics on my 1998 RM250, I'd have to swap subframes. I bought a used 2001 tank, new shrouds, new rear number plates, new rear fender, used 2001 seat, and a used 2003 subframe and airbox/boot.
The above link will show step by step progress, but I did encounter some pitfalls if you read it. Basically, to make a 2001+ rear subframe fit the 1996-2000 bikes, you need to relocate the lower left side bracket - It needs to move up about an inch. The main center point under the tank needs to be moved as well. I wound up welding threaded tabs onto the old location where the bolt went through - This really is the best way I could come up with to do this because relocating the tub for the bolt and using the factory style attachment wasn't an option due to the rear shock mount.
Next mounting the tank was fairly easy - Thanks to the idea from Cammeddr-z, I made some tabs that bolted to my tank, and then bolted to the frame - They didn't quite line up w/o them. Had to do the same type of thing with the lower radiator attachment point for the shrouds.
The only other thing was the airBOOT. I bought a used airbox/airboot assembly. The new airBOOT was a tad too deep, meaning when I bolted everything down, it was very squished in the frame. The solution was simply to use the 96-00 airBOOT, which was a direct swap from the new one.
I'm sure I'm missing something, but everything else was pretty much putting the plastics on. Aside from some welding (thanks to my awesome neighbor who builds hotrods), this is a fairly easy swap. I'm REALLY pleased with the results - I have a killer graphics kit that I still need to put on, but that will wait a little while longer, until I get a warm enough day.
Here it is: My 1998 RM250 with 2001+ tank and plastics. (I will be swapping the front number plate when I get my new forks to go with my new clamps.)
Here's a before and after:
Here are some others:
WHATCHA THINK??
