Spark Plug Cable
2 replies to this topic
  • mudhead
Posted 31 October 2009 - 04:15 PM
While working on my TE 510 I ended up pulling a little too hard on the spark plug cable and pulled it out of the cap & coil. Like in the picture below. I pushed the cable back in the coil and in the cap & the bike started and ran fine almost like it was designed to separate. My question is: Do I need to replace these parts, or is this designed to separate and be pushed back together?
  • Chris_Faherty
Posted 31 October 2009 - 06:12 PM
Normally there is a screw-like terminal which threads into the cable. So you should twist the cable on until it is thumb tight. If you have spare length, sometimes it helps to cut 1/4" off the end so it is fresh.
  • jrt-7
Posted 01 November 2009 - 09:03 AM
You need to replace it you pulled the resister apart inside the cap.
