Hi. I have just bought a beaut little 1984 QR50 for my eldest Daughter on ebay recently, and the front forks are partly seized. They do compress but do not release again. The normally smooth polished steel on the upper section of the fork has some surface corrosion on it, as it's been stored near the ocean for a few years. Any suggestions on how I can free them up and get them moving again?
Restoring seized front forks
Started by Filth, Oct 28 2009 05:49 PM
4 replies to this topic
Posted 28 October 2009 - 05:49 PM
Posted 30 October 2009 - 05:50 AM
sometimes you can have the forks polished to fix that problem, but you'll also want to replace the fork seals while you're at it, they'll probably start to leak eventually, so while you have it apart, you might as well do that.
You should also check to make sure the stanchions (inner fork tube) are not bent. This would also cause sticking. If they are bent, just replace the whole assembly from a salvage bike, it will be cheaper than buying new stanchions from the factory.
Posted 31 October 2009 - 02:57 PM
Quote
Exactly what I was thinking.
If they aren't visually bent then they are usually pretty easy to check/straighten if you have access to a bearing press, vee blocks and dial gauge on a stand.
Greg
