lighting stator
30 replies to this topic
  • fluffykins
Posted 28 October 2009 - 09:25 PM
Does any one know if someone makes a lighting stator for a rm 250. I know moose does but i hear bad things about it. I want to run two lights, 35w or 50w each.
  • cammeddr-z
Posted 29 October 2009 - 05:47 PM
you are totally screwed.the only manufacturer: moose (re-packaged electrosport) posted on this very forum just 2 days ago. that they are pulling the entire rm line due to problems
here
ESTRENT said:
Hello Guys,
We are completely aware of the Suzuki RM stator issues. To be honest we have pulled the entire RM line up off of our application listing and they will not even be included on next years application listing. The RM stators are being completely redesigned. I am very sorry for the people who have had issues with our RM stators and if you are still having issues please let me know and I will get you taken care off.
Best Regards,
Trent Kirby
Technical Sales Representative
Electrosport Industries
3803 Oceanic Dr Suite 201
Oceanside Ca 92056
760-842-8300 x1
760-842-8306 fax
www.Electrosport.com
  • MIKE ANIMAL
Posted 29 October 2009 - 06:23 PM
ur in luck i ran acrost this i looked 4 1 that would work i have an 06 & 08 rm250 none mounted right the yellow wire going to cdi tap it & fuse it 7.5amp fuse i have duel 35watthologen bulbs littledim at idl verry brite when moving
http://s679.photobuc...=NIGHTRIDER.flv hope this can help u i can send u vid 4 wireing if u want it
  • fluffykins
Posted 29 October 2009 - 07:58 PM
which stator are you using mike?
  • MIKE ANIMAL
Posted 29 October 2009 - 10:27 PM
stock as it comes what year is ur bike ill do the math after i check ur spec on what amp bulb or bulbs u need ill check back
  • fluffykins
Posted 29 October 2009 - 11:45 PM
  • MIKE ANIMAL
Posted 30 October 2009 - 11:27 AM
fluffykins said:
.2003
01 to 07 r the same i think my cdi is behind number plate urs is under the seat i think i will check ur wireing an get back with u is it under the seat
  • fluffykins
Posted 30 October 2009 - 12:21 PM
mine is also behind the number plate.
thank you for all the help so far.
  • MIKE ANIMAL
Posted 30 October 2009 - 05:02 PM
ok thats easy the yellow wire tap in to it put ur fuse as close to yellow as posable 5 or 7.5 amp fuse no bigger from fuse strate to + on light. find a good ground run it to the switch from switch to - on light if no switch from ground to - on light now what kind of light do u have one or to bulbs ill check back
  • fluffykins
Posted 30 October 2009 - 05:21 PM
i have two hella 500 lights. not sure if there 35 or 55w. if there 55w then i will probably get 35w bulbs. do you have a wiring diagram or a video or pictures you can send me so i can fully understand how to wire it.
  • MIKE ANIMAL
Posted 30 October 2009 - 10:01 PM
fluffykins said:
i have two hella 500 lights. Not sure if there 35 or 55w. If there 55w then i will probably get 35w bulbs. Do you have a wiring diagram or a video or pictures you can send me so i can fully understand how to wire it.
yes i do i will get that to u in the morning. Vid cam works better in day light ok bro
  • MIKE ANIMAL
Posted 31 October 2009 - 04:02 PM
had a long day have not forgot u
  • fluffykins
Posted 31 October 2009 - 05:35 PM
ok no hurry
  • MIKE ANIMAL
Posted 01 November 2009 - 09:54 AM
fluffykins said:
ok no hurry
Sorry it took so long. if runing to lights start with 30 amp lights. if it is not brite enough go 25 amp dont go to lo in amps. if you do go to lo in amps bulbs will blow. not a big deal go with 30 amp or 35 amp i run eiko lights part # 906bp from oraley
  • cammeddr-z
Posted 01 November 2009 - 10:20 AM
how does a 35 amp light vary from a 35 watt light?
  • MIKE ANIMAL
Posted 01 November 2009 - 01:12 PM
i am no expert.just no what works from exp with my bike. if u need to no . i will find out 4 u. i cant answer that unless i am sure. i dont want to give u wrong info. ok. sorry.
  • fluffykins
Posted 01 November 2009 - 09:13 PM
thankyou lots, that helps alot. when you tap into to the yellow wire do you just cut it put the other wire in so its likt a T? or can you put the wire in the plug part of it?
  • fluffykins
Posted 01 November 2009 - 10:00 PM
would tapping off the cdi box hurt the cdi box at all? or screw up the timeing of the sparkplug
  • MIKE ANIMAL
Posted 01 November 2009 - 11:30 PM
like a T this may sound funny. use a lighter in one spot heat the yellow coating up. pull coating off with your fingers. this is so you dont damage the copper wire in side. soder this conection if posabl. tape it up real good.
  • fluffykins
Posted 02 November 2009 - 12:52 AM
ok, alls i need is supplys
