02 rm250 rear wheel swap
10 replies to this topic
  • cooter450
Posted 27 October 2009 - 03:13 PM
Does anyone know if an 03 to 07 rear wheel will fit an 02 rm 250? Thanks.
  • cammeddr-z
Posted 27 October 2009 - 08:19 PM
yep, straight across, any rm 01-newer will swap rear wheels, and any rm 1989-present will swap fronts, as will 1998-newer yamaha front wheels are also a direct fit
  • cooter450
Posted 28 October 2009 - 08:12 PM
how about an rmz will they interchange with the rm's
  • tim2007
Posted 29 October 2009 - 11:56 AM
I don't know about the RMZ450, but the RMZ250 wheels will not swap straight into an RM250. No doubt if you made up a load of spacers etc you could do it, but they are quite different.
  • cooter450
Posted 29 October 2009 - 05:01 PM
Thanks for the help, :thumbsup:
  • cammeddr-z
Posted 29 October 2009 - 05:44 PM
THE RM-Z'S are different both front and rear
  • sahzooki
Posted 29 October 2009 - 06:08 PM
While this thread is up I have a question....
What rear wheels will fit the 89?
  • cammeddr-z
Posted 29 October 2009 - 07:18 PM
89-98 rm's, and rm-x's for sure, on my 1991 i took a newer 01+ style rear and axle, and just opened up the swingarm, and brake caliper to accomodate the bigger axle so that all of my wheels interchange on all of my bikes, the only differences is that the 01+ has a larger axle, besides that the hubs, the spocket spacing, and brake disk spacing are are the same
  • sahzooki
Posted 30 October 2009 - 02:45 PM
Good to know. thanks man!
  • Dante04SRT
Posted 15 December 2009 - 06:20 PM
Maybe its just me, but I'm still confused - Will my 98 rear wheel fit a newer swingarm/axle? Since its really the bearings and the spacer inside that the axle goes through, would I need a newer rear hub or can I just get the newer bearings/inner spacer?
  • sangheraent
Posted 15 December 2009 - 06:40 PM
i have a 06 kx250f rear wheel on my 01 rm 250. Its identical to my stock wheel and I bolted it up perfectly
