Wouldn't a rotary engine motorcycle be a more powerful machine? The Mazda RX8 uses a rotary engine that is only 1300cc, or 1.3L engine, and produces around 220 break horsepower. If that is so, wouldn't a 500cc rotary engine produce far more power than a current 4-stroke engine? if this is so, what are the complications that would keep an engine like this from being implemented in a motorcycle?
Rotary Engine Motorcycle?
Posted 26 October 2009 - 02:57 PM
Posted 26 October 2009 - 03:02 PM
Suzuki made a street version a long time ago...
http://www.suzukicyc...E5-Rotary.shtml
Posted 26 October 2009 - 03:07 PM
As a result of using ports to allow fuel in and exhaust out of the motor, and there is no cooling for the exhaust, the exhaust headers get really, really hot.
And also, the emission control gear to keep them clean enough to run in the USA is rather large and heavy. They have exhaust emissions like a two stroke to clean up.
If those little issues could be solved, we'd have a winner.
Posted 26 October 2009 - 03:18 PM
And for sure check out this link...
specs/' class='bbc_url' title='External link' rel='nofollow external'>http://www.race-spor...0-wankel-specs/
Posted 26 October 2009 - 03:35 PM
That Kart engine is a prime example! Imagine if a giant company like BMW put their R&D division on designing a rotary engine motorcycle, it would be an amazing piece of machinery! And BMW motorcycles always seem to have technological advances that give them advantages over other motorcycles, a rotary engine would be a perfect fit the for the company, and that could transfer over to Husqvarna. Give Husky something to truly set them apart from the big 4 and KTM!
Posted 26 October 2009 - 04:07 PM
Saachs made several small wankel powered street bikes, and a couple dirt-ish (similar in size and performance to an XL185) bikes in the '70s. I have a Dirt Bike magazine from the early '80s stashed away which briefly mentions some europeans racing a wankel powered MX bike.
Saachs also made wankel powered lawn mowers and a few wankel chain saws...
Posted 26 October 2009 - 04:41 PM
Norton rotaries in sight and sound :
wow, listen to that. Who cares about a little smoke?
Some more rotaries from different manufacturers at http://www.motocyclo...otorcycles.html
Edit: Silly me, I completely neglected to mention that Norton rotaries are still alive and kicking (although given Norton's history one wonders how long for...)
http://www.nortonracing.com/
Posted 26 October 2009 - 05:21 PM
Posted 26 October 2009 - 05:36 PM
Krieg said:
the RX8 is a wonderfull engine. Many RX7 motors in plains.
I forgot about the Norton one. They still make police bikes with that motor in it because it runs forever and needs little maintenance. Stories of 500K + miles on a lot of them.
http://www.nortonrotary.org.uk/
Posted 26 October 2009 - 06:01 PM
Krieg said:
I really feel that if we put the power and expertise of today's engineers to work, we could have a more efficient machine than in the past.
Posted 26 October 2009 - 06:15 PM
Anyway, hang the efficiency, just put a bigger fuel tank on! Rotaries make great race engines (just like 2-strokes). Everything that's fun gets banned in the end. ;)
Posted 27 October 2009 - 10:33 AM
Posted 27 October 2009 - 11:00 AM
Good designs have a way of taking over due to their own inherent superior properties (don't wanna hear any 2t vs 4t comments!) or benefits. The rotary never took hold, draw your own conclusions.
I do love the rotary design, but I'm pretty sure it would be nearly impossible to make one compact enough to satisfy todays dirt-bike demands. Noone wants an overweight powerplant that relies on revs to do a job.
Posted 27 October 2009 - 11:54 AM
Posted 27 October 2009 - 12:24 PM
http://www.ski-doo.c...ch/en/Index.htm
Posted 27 October 2009 - 04:13 PM
direct injected 2 strokes? Yep, we all want that.
Posted 27 October 2009 - 11:06 PM
Ride said:
Posted 28 October 2009 - 01:29 AM
Posted 29 October 2009 - 06:02 AM
WEIRD STUFF! COATES SPHERICAL ROTARY VALVE ENGINE:
THERE ARE NO VALVES, JUST A SERIES OF SPHERES ON A ROD: SORT OF A SHISH-KABOB
Unlike a conventional piston engine that ignites the fuel and air mixture in the combustion cycle and evacuates the gas byproducts in the exhaust cycle via the rotation of the camshaft and spring-loaded poppet valves (with springs, valve guides, buckets, rockers, shafts and the valves), the Coates Spherical Rotary Valve Engine is made up of spheres rotating on a shaft sandwiched between a split head. These spheres are either chain or belt driven via the crankshaft, much like an overhead camshaft. Each sphere rotates against a matching seal between it and the piston, one for intake and one for exhaust.
The spheres have cavities and ports machined into them for the induction of fuel and air on the intake stroke, and the evacuation of fired gases on the exhaust stroke. This design performs exactly the same function as poppet valves, but the design eliminates the poppet valves, valve springs, guides, camshaft, pushrods, rocker arms and other smaller parts.
The Coates engine operates with over 100 fewer parts than convention engines. It avoids the problem of oil burning by requiring no oil lubricants for the valves. Moreover, the rotation of the spherical valve heads reduces engine temperature by constantly changing the surface exposed to combustion heat.
The spherical rotary valve design can accommodate higher compression ratios than conventional engines. High compression ratios can be utilized incorporating the Coates more efficient and powerful short-stroke design, while maintaining the desirable characteristics of optimum performance using lead-free gasoline. The maximum rpm on the poppet valve engine were 5700 rpm. Plus, there are fewer components and thus lower costs.
http://www.coatesengine.com/
Posted 29 October 2009 - 07:50 AM
thats a really cool setup and I have been watching it for years wondering if it would ever take off. Even contacted them several years ago to see if they would sell me a single cylinder head to graft on a 4 stroke motorcycle. No interest in that and if so big $$$ they had big issues sealing it on the compression stroke but some floating seal ring fixed the issues I guess. Cool stuff.
You and I should never get together for a chat as it would be an engineering geek fest. :lol:
