ways to detune a 08 yz450
10 replies to this topic
  • qwert321
Posted October 26, 2009 - 02:29 PM
I know most people dont want to detune there 450 but I ride a yz144 most of the time but also own a 08yz450. problem is that even with stock exhaust it is way to much bike when I get on it. looking for a cheap way to tame it alot I am talking more then 250f but less then what a 400 would be.thinking best would be to restrit exhaust more but worried that motor would produce more heat.
Posted October 26, 2009 - 02:36 PM
Install the exhaust cam from an '06 or '07 WR450, and add the heaviest available flywheel.
  • Bryan Bosch
Posted October 26, 2009 - 02:41 PM
Moose Altered Ratio Throttle Cams
http://shop.thumpert...fault.asp?p=341
G2 Throttle Cams
http://shop.thumpert...fault.asp?p=165
I don't use, but I've read others have had success with them. Maybe do a little digging on them.
  • gfmoto
Posted October 26, 2009 - 08:36 PM
the cheapest and simplest fix it to add one tooth the front counter shaft sprocket, for $15 you will have a much more mellow power delivery.
  • T Bolt USA
Posted October 26, 2009 - 08:41 PM
thats exactly what i was going to say ,,,,old school cheap fix
  • FinchFan194
Posted October 26, 2009 - 08:50 PM
Well I stuck 14/47 combo on my 08 and it tamed it too much (13/49 is stock) I backed down to a 13/47 combo and the bike hooks up pretty well now and isn't geared so high in first maybe you could also try the GYTR offroad FWW. I have one on my bike and I wouldn't say it tames the bike just makes it a lot funner to ride.
  • wondermuscle
Posted October 29, 2009 - 09:34 AM
You could put in a WR thorttle stop. It is simple.... Remove the yz throttle stop and intall the WR version.
I think you can buy the WR version.... If not, I'm sure you can find a machine screw that is the appropriate length.
  • CanadianWR450
Posted October 29, 2009 - 04:53 PM
You will have no problems finding WR owners on here willing to trade you throttle stops....:smirk:
The 50% throttle restriction will certainly accomplish your goal...
  • psmith85
Posted October 29, 2009 - 05:16 PM
Gearing or flywheel weight. I like the idea of the 14 tooth sprocket. As you get use to the power you will be able to use the gearing to change the power to your liking.
  • FinchFan194
Posted October 29, 2009 - 05:44 PM
two words-throttle control. . .just sayin.
  • Family Man
Posted October 29, 2009 - 09:11 PM
Why would you ever want to detune your bike? ***. After all, a tuned bike plus practice= fast and fun.
  • Hot  38 replies
  • 0 replies
