Many of you know i sent my suspesnion off my 09 WR125 to Richard at House of Horsepower. i have known Richard for many years, he used to do work here in Oregon and is now in Oklahoma. I asked for a simple revalve to make the suspesnion plusher and more compliant. i said i wanted trail plush but controlled. he called me back and said he wanted to do a full on top of the line job with DLC fork coating, hard anodizing, shock spring binding eliminator etc. What the heck, go ahead. So i wait about a month and get it all back. Looks fantastic. Hope it works as well.
So i bolt it all up and if feels good on the stand but the rear feels stiff. I take it on a quick ride in crappy conditions, rain, slick clay, rocks, night ride. I came away kinda unimpressed and scratching my head. The forks felt good but the rear felt tight and firm. so next ride is at my favorite place, killer single track for miles. Lots of big root wads and rock step-ups to slam into. I'm liking the forks but the rear is still unforgiving, good but not plush. At one stop I'm fiddling and thing, "you know what, these forks got shipped across the US, I should bleed the air out" WOW, it was like it had 15 PSI in there. From that point forward i was in love with the forks. plush and controlled just liked I asked. They have the amazing ability to soak up trail trash and roots / rocks yet stay up in the travel and very composed as things get faster and nastier. I could not be more happy with the forks at this point. Amazing control and plushness at the same time. Did not know this was possible, I always felt you needed to choose plush or controlled he delivered both.
The rear I was still semi unhappy with. I was expecting a lot from this fancy suspension job, the forks are delivering but the rear seems stiffer and worse than stock which was actually getting very good. So i called Richard and explained my delema. He said "no way, it is a good 25% softer valving and was afraid he made it to soft" He was sure my sag needed set (which i did not do, my bad) and that i have way to much preload. I checked it and was just short of 4 inches but almost no static sag. The rear of the 1 2 5 weighs almost nothing so static sag is hard to get. I backed the shock spring off a lot and got to almost 4.5 sag which is on the high side.
Flash forward to the next ride. WOW, these bikes are sensitive to sag. All of a sudden the rear was SOFT and compliant as all get out. So soft i had to start turning in the adjusters I had all the way out. After sorting what settings i liked I could not be happier. The rear is PERFECT as in everything disappears and yet the bike is still very controlled and never hops / deflects.
It took a little setup to get where i wanted it but the suspesnion is excellent. Not good, but GREAT. i feel so confident on this bike now. Right now i am so happy with the little 125. The suspesnion is working PERFECT, the changes I have made with the jetting not only fixed the mid hole but now have a mid surge in power and the Motoz with low pressure are rocking. The whole package is amazing. So fun to ride, climbs almost anything, turns better than any bike i have ever ridden, the faster you go the better the bike gets. Always urging you to wick it up and then rewarding you for doing so. The last few rides have been nirvana. Just railing in a zone on a truly great machine.
