426 high rpm sputter
8 replies to this topic
  • shrekmoose
Posted October 25, 2009 - 04:08 PM
I just recently developed a high rpm sputter on my 2001 426. bike sat for about a month (had a broke subframe bolt to fix) and when I fixed it and started it now has this sputter. I noticed when I was doing my subframe that my exhaust band clamp was loose and exhaust could just be pulled off by hand. So I tightened it all back up and while it has got rid of my popping on decel, it makes it to where when i open it up with the rpms up it misses and kinda sputters. Any ideas what this may be? maybe jetting is off now?
  • phart2005
Posted October 26, 2009 - 04:21 PM
Hows the spark plug look?
  • shrekmoose
Posted October 27, 2009 - 12:46 PM
good question ill look when I get home.
  • Lor
Posted October 27, 2009 - 07:09 PM
Old gas???
  • DrThumper
Posted October 28, 2009 - 01:42 PM
Main jet clogged, lacquered up from non-use.
  • shrekmoose
Posted October 29, 2009 - 02:50 PM
so in other words imma have to tear into my carb no matter what pretty much. I am hoping its in the carb, i have lost alot of compression until it warms up. I assume my rings are not sealing well. So looks like there is a top end in the near future. Would that have anything to do with the miss?
Posted October 29, 2009 - 03:42 PM
... i have lost alot of compression until it warms up.
That is a symptom of tight intake valves.
  • shrekmoose
Posted November 01, 2009 - 12:31 PM
would that cause the sputter, or is that more than likely just cause its an older bike and never had the valves adjusted before?
Posted November 01, 2009 - 04:01 PM
Dirty carb, bad plug.
  • 0 replies
  • Hot  50 replies
Motocross
  • Hot  491 replies
