2003 Rev 600 H.O
11 replies to this topic
  • crf250riderz
Posted 25 October 2009 - 02:38 PM
Hey i am looking for feedback ASAP. I am looking to buy a 2003 Rev 600 H.O with the beaver tail delete kit, 3" Risers, Mid height aftermarket windshield. The reverse does not work on it but he claims that if you clean the clutch on it it should work, 6900kms. I am fine with doing a top end after this season and know how much it is. How much is a new clutch just incase a the clutch is screwed. He will take $3,500 CAN  there is sled around where i live that don't have problems for $5,300CAN. Worth the price or gamble?? would like to know the price on a clutch
Thanks a lot and would appreciate some feedback thanks
Edited by crf250riderz, 26 October 2009 - 09:19 PM.
  • Refg3880
Posted 01 November 2009 - 06:48 PM
That has rer which means when you push the button for reverse the motor will stop running for a moment and then restart backwards. If the sled goes forward but not in reverse it's not the clutch.
  • crf250riderz
Posted 01 November 2009 - 06:52 PM
what is it then?? something electrical
  • Autoteach
Posted 01 November 2009 - 07:02 PM
the ignition is cut and when the engine slows down enough and is coming up on the compression stroke, the ignition fires btdc to cause the engine to reverse rotation.  The primary clutch operates normally, but the secondary must have reverse ramps to accommodate this function.  You will not likely have to do rebuilding on either clutch for 8-10k miles.  The engine on the other hand could leave you stranded if it all original.  The rings have a coating that flakes and you lose hot compression.  If this happens you need to let the whole thing cool until you can start it.  Totally lame, but rings will bring it around.  How many miles?
  • crf250riderz
Posted 01 November 2009 - 07:10 PM
it has 6900kms on it and so what is stopping the reverse from engaging? i'm a newb sorry
  • dirtbikekid32
Posted 14 November 2009 - 04:13 PM
Could be a switch problem.. Hard to say without diagnosing it..
That price is pretty high for a 7 yr old sled!! You can do alot better than that.. Shop around a bit..
  • crf250riderz
Posted 15 November 2009 - 10:47 PM
i found an 03 rev 600h.o that is a different one with a new track and top end. bought it for 3,500CAN that is a pretty good deal for around here. the guy sold it so cheap because he needed the cash quick because everybody around here always goes down to the states buy a bunch of cheap sleds that are expensive around here
  • mike337
Posted 20 November 2009 - 03:57 PM
My brother had one. Great sled. Little tough on gas tho. Ski-Doo clutches are near bullet proof, so no worries there. Enjoy your sled.
  • crf250riderz
Posted 20 November 2009 - 08:53 PM
ya this one looks like a pretty fun drift pounder and carver haha. i dunno how the 600 motor will be tho for power how was your brothers for power?
  • mike337
Posted 21 November 2009 - 06:34 AM
I think it was plenty fast! Everyone else will argue that and tell you they beat one in a race one time. How fast is fast enough? Point is, its plenty.
  • crf250riderz
Posted 10 December 2009 - 01:47 PM
took it for a little rip up the field (not much snow STILL) yes it has plenty for right now. now all i gotta do is set the suspension to lift the skis
  • bfino2
Posted 18 August 2010 - 05:10 PM
i have a 2005 skidoo 600 H.0 rev... it fast and fun
