WR 450 '03 and '04 Crankshaft
3 replies to this topic
  • dazzabb
Posted October 21, 2009 - 06:45 AM
Fella's,
Are these two parts interchangeable?
Seem to remember reading about some woodruff failures on 03 models, did anything change on the 04?
Buddy in Thailand needs new conrod/bearings but likely cheaper to get a crank.
  • PBDBLUE
Posted October 21, 2009 - 07:50 AM
03 and 04 have different flywheel tapers and diameters. You can use one or the other but you have to have the matching flywheel to go with it.
  • dazzabb
Posted October 21, 2009 - 05:17 PM
Excellent info, thanks PBDBlue, you've saved me a lot of time and frustration!
  • PBDBLUE
Posted October 21, 2009 - 06:48 PM
No problem. I went through this same decision when I rebuilt my '03. I decided to stick with the '03 crank since I already had the flywheel. The keyway problem was resolved with the '04 starter drive upgrade which I highly recommend doing. Once the upgrade is done you will not have a problem with either crank.
