I've literally spent over 5 hours searching every known husqvarna site for stock or aftermarket husqvarna clutches online. Can somebody please assist me in finding a NEW 2008 husqvarna txc 250 clutch kit. Mine doesn't pull under heavy throttle and instead of possibly replacing the spring i want to just replace it all with a kit. Just no auto clutches thanks!
Where does the internet hide husky txc 250 clutches?
Started by fabhusky, Oct 20 2009 11:43 PM
14 replies to this topic
Posted 20 October 2009 - 11:43 PM
Posted 21 October 2009 - 02:49 AM
Check with the Thumpertalk store, or call Halls Husqvarna, they'll hook you up.
Posted 21 October 2009 - 04:15 AM
I have also heard of people using slipper clutches like the ones used for road racing and supermoto in their dirt/MX bikes. Rumor has it Chad Reid swears by running a slipper instead of a traditional clutch. They are big $$ though. Here is a link to one for your bike as long as someone can confirm that the clutches for the 450/510 are the same as the 250/310:
http://www.motostrano.com/adslcl.html
Posted 21 October 2009 - 06:18 AM
Alright i messaged thumpertalk and am waiting for a reply. Halls Husqvarna... is there a website? (i live near toronto btw). My last option would be the expensive slipper clutches, just cant find one thats made for a 250. Hopefully someone confirms whether the 450/510 will work. thanks guys for the help so far.
Posted 21 October 2009 - 09:40 AM
https://www.halls-cycles.com
(217)789-0107
Posted 21 October 2009 - 11:19 AM
yep Halls- and I am not aware of any aftermarket company
Based on the Parts Fiche: the 250 has a separate clutch pack than the 450/510
8000A0611 CLUTCH PACK 250 4ST $157.99
8000A0730 CLUTCH SPRING $2.99 /per you need 6
I would inspect it first- check minimum specs- I don't have that info available to me right now...
Posted 25 October 2009 - 12:32 AM
I opened up the clutch last night and the springs are at about 39 mm and the basket had grooves in it :( Should i file the grooves out lightly and put some metal washers with the springs, 2 mm ones? book says 41 mm stock 39 mm wear limit. New plates and springs will run me over 200$... what do u think? Thanks guys.
Posted 26 October 2009 - 09:10 AM
check the lining disks thickness: .118" or 2.997mm (new) and .114" or 2.896mm (min thickness) if they are out of spec you have to replace- to bad you can't just buy the ones that are out of spec- maybe a dealer would sell just the ones you need? never know... I was suprised to see them only sell the whole pack in the fiche.
inspect the plates for warping and scorring (I did not find a min spec on the plates)
you could use washers/ or just get new springs- 6$per (maybe try just 4 new and 2 old)
the basket grooves shouldn't cause slipping- would be grabby(not smooth)- hopefully the grooves are just marked and not deep- I would not file it but but depends on how deep they are. That would increase the min lateral spacing of the slots ( should not be .6mm or more). Sounds like they arent causing a problem.. yet
Posted 28 October 2009 - 06:22 AM
Alright thanks man. I'm heading to home depo today to get some washers (2mm) see if i can temp fix this for the winter then next year buy some plates and springs. The basket is not grooved, the internal aluminum piece is grooved where the metal plates lock into. Don't know what its called. Do i need a new one? Ill let u know how the washers go. the ones i put in were 4 mm and the clutch is stuck engaged lol
Posted 28 October 2009 - 10:39 AM
Called a clutch center hub, should not be a big issue.
Posted 28 October 2009 - 02:19 PM
Rather than tossing the clutch just take it apart, wash it, seperate the lined discs from the unlined (intermediate). Then stack the intermediates in a group and check for gaps. A gap is a sign that one is warped, commonly one or two intermediates may be warped but rarley the set, replace any that are warped
Next with course sandpaper (80 grit is fine) and a wood block vigorusly block sand both side of the intermediates!
Then with something a bit finer, 220 as an example sightly block sand the lined discs.
Wash, soak in oil, the same oil your going to run, reassemble, make certain you do not run the oil level too high!
Posted 28 October 2009 - 10:53 PM
Ill try 2 mm washers and then your fix dave. I didnt see any gaps so maybe there glazed. ill try the sanding and hopefully save myself 250$. Thanks for the adive man.
Posted 29 October 2009 - 04:15 AM
Surflex Clutches: http://www.surflexcl...s.com/Home.html
Surflex Catalog: http://www.surflexcl...es/Off-Road.pdf
BlipBlip/HuskyRips :thumbsup:
