which throttle cable do I use?? yz400f w/ 450 carb??
12 replies to this topic
  • Thinblueline
Posted October 20, 2009 - 06:05 PM
Hey guys Im new to the site and have been searching threads for my questions with no avail. I just bought a 99 yz400f and its in great shape. the seller stated he bought a "450 carb" off ebay and put it on the bike to help with performance and starting issues. The bike runs decent, but the carb doesnt feel 100% tuning wise. I noticed today when looking over the bike, he was still using the stock 99 throttle cable which looks too short for this carb and the cables are frayed so I need two new cables. I need to know what year throttle cables do I need for this application to work. He said the 450 carb came off a quad 450. Also is there a base line where I can set the 450 carb and go from there? thanks guys and gals in advance! Very much appreciated!
here are pics of the carb. can anyone tell me the specifics on this carb and how to set it up, IE: where to set the red knob, like how many turns out just to get me started. thanks again I do appreciate it.
Edited by Thinblueline, October 20, 2009 - 06:31 PM.
  • 426 NOOB
Posted October 20, 2009 - 06:31 PM
I would try a yz 426 cable and see if that will work. My stock 426 cable is a few inches too long because I have 2inch risers and 4inch tall bars, and the cable still fits with enough play. Also try the jetting stickey at the top of the page. Lots of people have tried different things with carbs and posted their results.
  • Thinblueline
Posted October 20, 2009 - 06:36 PM
can you tell me what carb this is from? I posted the pics right after you replied. thanks for the reply! I hope the 426 cable works. the stock 400 cable is like an inch short.
Posted October 20, 2009 - 07:32 PM
What is the number stamped on the left side of the carb at the float bowl joint?
  • Thinblueline
Posted October 20, 2009 - 07:39 PM
looks like it reads: STGI 00SB09
after looking online at different carbs it looks like its from an earlier YZF450. What do you guys think? If it is, which throttle cable for my 99 yz400f? thanks
Edited by Thinblueline, October 20, 2009 - 08:07 PM.
Posted October 20, 2009 - 08:08 PM
That's more likely 5TG, but I don't find it listed. A Yamaha dealer may be able to run the number for you. The fixed fuel fitting suggests an '03, but an '03 YZ450 would be marked 5TA.
  • foggy3061
Posted October 20, 2009 - 09:23 PM
You may want to fit the hot start plunger too, the threaded hole on the front left of the carb when looking down on it from above. Just next to your thumb in this pic:
Now is a good time to fit all the bits for the cable operated hot start and mount it on your front brake perch (CR450F style). :bonk:
  • umu24013
Posted October 20, 2009 - 10:30 PM
it's definitely a YFZ450 carb!
  • Thinblueline
Posted October 21, 2009 - 04:27 AM
ok thanks for the quick replies! Now two things, which cable do I need to get to make this work on my bike? And can i use my old hot start set up and just plug the port on the carb? thanks
Posted October 21, 2009 - 09:01 AM
Notice where the idle speed adjuster is? Definitely NOT from a YZ/WR450F motorcycle.
5TG is an '04 quad carb. Probably OK to start with, but it may be a bit of a PITA.
  • foggy3061
Posted October 21, 2009 - 10:08 AM
I dare say that '04 YZ throttle cables could be used to allow it to work with your bike, tho', i have never seen YFZ carb in the flesh so i ain't 100% sure if it is possible!
As for the hot start, you wouldn't be able to use your plunger (you would struggle to pull it on, as the bottom of the tank might be in the way - if there's even clearence under the tank to pull it up?).
You will have to fit a YZ style hotstart plunger and cable and have a remote hotstart on the bars i'd guess
  • Thinblueline
Posted October 21, 2009 - 02:33 PM
update. i messed with the bike all day today. I put the stock carb back on which is jetted to the fmf header and air filter with no lid. I cleaned the stock one and put it back on and the bike seems to run good. a little bit of popping at low rpms but other than that its good. so now I can get the right throttle cable for my bike and sell this 450 carb. any idea how much I can get for it? Thanks for all of your help guys!!
  • umu24013
Posted October 21, 2009 - 07:30 PM
You can do a completed listings search on eBay
http://completed.sho...r&LH_Complete=1
  • Hot  30 replies
  • Hot  38 replies
  • 3 replies
  • Hot  113 replies
  • Hot  28 replies
