'05 YZ 450f, New Top End?
1 reply to this topic
  • DRich43
Posted October 19, 2009 - 03:28 PM
Hello All,
How do you know when you need a Top End...I check my valves a few times a year, change my oil way too much, clean my air filter all the time but i just want to know what to look for.
I just cant afford a little problem turning into something too expensive...
Thanks,
Posted October 19, 2009 - 03:41 PM
When your valves need to be shimmed two sizes (.10mm) smaller, and/or won't stay adjusted more than a few hours, you need valves.
When the engine fails a leak down test, you need rings, and possibly a piston. More than a 10-15% loss in a leak down is usually pretty much a failed test, but that depends a great deal on the particular tester used, as there is no real standard by which they are made.
You can also go by time or mileage, and a visual inspection of the piston and bore. The life of the bore itself can sometimes be almost doubled by replacing a piston before it quite really needs it.
  • Hot  113 replies
  • Hot  36 replies
Motocross
  • Hot  491 replies
