Taller handle bars?
21 replies to this topic
  • KAISTIE
Posted April 20, 2003 - 05:00 PM
Hey guys!
I am 6'-4" tall and am starting to develop a serious problem with the way my bike is laid out. :) As my skills increase, I find the seat-tank junction to be very uncomfortable. Also, the handle bars seem to be way too low. I know there is a YZ seat-tank kit you can buy and put on the WR which I think would help my situation greatly, but I would like to try taller handle bars first. Is there a kit that will allow me to raise the handle bars a few inches, and push them forward at the same time?
Thanks!
  • SMD
Posted April 20, 2003 - 05:14 PM
Renthal Jimmy Buttons..........Highly recommend.Great for us above average folks. :)
  • MOmilkman
Posted April 20, 2003 - 05:20 PM
The most extreme position you can move your bars up and forward (that I know of) is with Thumper Racing Goliath Bar mounts. They move them 1.5" up and 1.5" fwd.
Heres a pic of them on my bike. I made a HUGE diffence in the handleing charatersitics for me. (Im 6'7")
  • live_to_ride
Posted April 20, 2003 - 06:18 PM
I've got an ims 3.4 gallon tank that I could sell ya for cheap! It looks like new. Let me know if you're interested at onefastctd@hotmail.com Those bar mounts look like exactly what I want!!! I'm 6'4" also. Thumper racing's site is down. Where could those be purchased, and how much are they? thanks
Chris :)
  • Parx_400
Posted April 20, 2003 - 06:55 PM
wow those mounts are big. try lowering your pegs. there is a mod that is on the site you can search for. it helps alot. you are soo tall you could do a higher seat. i am 6,2 and tried a high see but went back to stock yz. i also have cr double high bars and +10 taller risers.
parx
  • live_to_ride
Posted April 20, 2003 - 08:16 PM
Anyone have ideas for better levers for big feet? I am always catching the levers with my boots, and shifting when I don't want to. I've been toying with the idea of extending them. :D
Chris :)
  • MOmilkman
Posted April 21, 2003 - 03:18 AM
the site is working now... or at least for me.
http://www.thumper-racing.net/
or try Baja Designs. They sell Thumper stuff I believe.
(not sure of their website) :)
  • KAISTIE
Posted April 21, 2003 - 04:38 AM
I can't find the Goliath bars on thumper racing. I looked all over several times and still no luck. I did find the Renthal Jimmy Button bars. Will those be tall enough? Also, what about all my cables? Will I need to lengthen everything?
Thanks for all the help guys! I am getting excited to finally get this resolved.
Nate
  • MOmilkman
Posted April 21, 2003 - 05:29 AM
Yea, thumpers website has to be the worst aftermarket website out there.
Let me look around and see what I can find and I'll get back. I got mine from my dealer.
  • MOmilkman
Posted April 21, 2003 - 05:52 AM
Ok, here ya go.
I found them on www.bajadesigns.com
Click the link above then,
click "Motorcycle store"
then "Controls"
then "Handlebars"
then scoll down a bit and you will see it.
Click on it and they list them for several applications.
They are avialable in 1" and 1.5" (what I have).
2 things first though..
Your cables should have just enough room (mine did), if not then I know Thumper Racing makes custom cales. (they are expensive if I remember right)
Also, your triple clamp has to be a aftermarket (not stock) so you can remove the bar mounts and put these on. Also I believe you can get them for Std bars or Oversize bars (ProTapers). I went with ProTapers :)
Although, I dont see on thier website where you select between the ProTaper or the Std mounts. You might want to e-mail them and ask. (Or call them if you want a faster response)
  • KAISTIE
Posted April 21, 2003 - 06:09 AM
Thanks for the link. I guess now I just have to decide if I want to replace the triple clamp and put the taller mounts on, or just replace the handle bar, or both.?
Are my mounts welded to the stock clamp? I don't have access to my bike right now so I can't check. Is there any way to make it work without new clamps?
  • MOmilkman
Posted April 21, 2003 - 06:42 AM
I wouldnt think there is any way to make it work with stock triple clamps. I see you have a 2002 bike so I'm not 100% sure your bar mounts are'nt removeable but Im fairly certain they are not. Mine bike is a 99 so they could have improved the TC since then.
Check the "for sale" forum for aftermarket TC's. Seems like they pop up on there all the time. good luck! :)
  • KAISTIE
Posted April 21, 2003 - 07:34 AM
Thanks!
I checked and you are right. The lower part of the mount and the clamp is all one piece. :) Oh well, I guess I now have an excuse to buy new triple clamps! :D
Thanks again for the help :D
  • DesertChris
Posted April 21, 2003 - 08:14 AM
Nope, '02 in no different. They also have cast in bar mounts.
  • MOmilkman
Posted April 21, 2003 - 08:18 AM
And I wanna know when Yamaha is gonna step up and do something about that? :)
They need to make all their stock TC's with removable bar mounts so us taller rider can adjust easier.
I wonder if they know that everyone is not 5'8"... :D
  • KAISTIE
Posted April 21, 2003 - 08:33 AM
On top of all that Baja Design said that the larger riser is on back order indefinately. So I guess it's either new top triple clamp, riser, and bar, or just a taller bar. For cost reasons I am going to just get the bar, and do the footpeg mod tonight. Hope this puts me in the right position. :)
  • Rich_in_Orlando
Posted April 21, 2003 - 09:32 AM
Here's one way to do it: Posted Image
  • KAISTIE
Posted April 21, 2003 - 09:45 AM
How can I do that?? I just purchased a new set of Renthal Jimmy Button bars, but would like to do exactly what you did also. :)
  • Rich_in_Orlando
Posted April 21, 2003 - 09:52 AM
Those black things under the handlebar are just a set of upside-down handlebar pinch clamps. I had an extra set off a trashed top triple clamp from an old XR250. Then get some longer pinch bolts and you're done. It raises the handlebars about 5/8".
  • KAISTIE
Posted April 21, 2003 - 10:05 AM
Thinking outside the box...nice! The idea of doing this actually crossed my mind today, but being that I am a novice rider I dismissed it and and asked for advice. It looks like you have had no problems from the picture, I think I'll give it a go. :)
Thanks!
