Coolant alternatives
2 replies to this topic
  • Tim
Posted July 05, 2000 - 07:24 AM
Back when I was doing my "new bike" research, I came across something on the net that told you to use some kind of "Water soluble oil" instead of anti-freeze. Anybody do this? I guess it is supposed to protect the aluminum for corrosion. With a set of radiators around $700-$800 I think it is something to look into. I am aware of the "water wetter" product. Is this what they are talking about?
Thanks Tim
  • Guest_Guest_*
Posted July 05, 2000 - 08:10 AM
Tim,
I don't know about the stuff you are talking about, but most good antifreeze is safe to use in aluminum radiators.
Nick
  • JBM
Posted July 06, 2000 - 06:17 AM
Tim, it was Motocross Action that recommended the water soluble oil. They said you can get it at Pep Boys for real cheap. I have never looked or heard of it before and I don't know if works or not. Maybe someone else knows something more about it. The Water Wetter is a coolant additive made by Redline. It's supposed to allow the water in your radiator to more effectively transfer the heat from your radiator walls. I haven't used this either. You can check out the Water Wetter at http://www.redlineoil.com if your interested.
