Honda
Rubicon 500 ( GRINDING!! )
13 replies to this topic
  • Sandflea1977
Posted January 15, 2009 - 03:59 PM
i have a Foreman Rubicon 500 that starts grinding about 30 seconds after i start moving, i did an oil change about 3 months ago, what gives? :bonk: someone please help me, i cant figure it out :bonk: and i really rely on this bike:cry:
  • mickeydee
Posted January 16, 2009 - 02:06 PM
drain the oil and look for any metal bits coming out.it sounds like a gear has gone bad in the transmission.but you say it happens 30sec after you start moving.if it was a gear i would think you would hear it all the time not 30sec after it starts to move.it very well could be somthing in the clutch
  • Sandflea1977
Posted January 16, 2009 - 04:54 PM
the clutch is what i was thinking after looking through the Clymer repair manual, and from what it looks like in the book, no matter the problem i'm probably going to have to pull the motor :bonk: and that is never an easy task :bonk: , Thank you for the reply :bonk:
  • mickeydee
Posted January 16, 2009 - 08:19 PM
pullin motors out of any quad sucks but honda's seem to be easier than some others ive done
  • HUSKYRIDER360
Posted January 17, 2009 - 11:15 AM
Pulling this motor out is not an easy task.
what year honda is this?, if its before 05, you got a good chance the hondamatic unit has failed. it is a complete replaceable unit, not cheap, and hard to find, becouse any that you find parting out will most likely becouse of this. I've been there, found one on ebay that i made an offer on.
  • trxmaster88
Posted January 17, 2009 - 01:06 PM
yeah it dose sound like its the clutch becuse it use a centrifical to gice power to the main clutch pack. remeber to change your oil before 600mi. cuse your hondamatic realise on the oil cause thats what drive it. there are no gears involved in it. 10w40 is what the man calls for.
  • Honda Mechanic
Posted January 18, 2009 - 04:37 PM
Grinding/ratcheting usually needs a new Hondamatic unit ...
  • Sandflea1977
Posted January 18, 2009 - 06:17 PM
Does anyone know what this illusive " Hondamatic " looks like or where on the motor its located?? :bonk:
  • HUSKYRIDER360
Posted January 18, 2009 - 07:18 PM
http://xtremeusa.com...tion_detail.asp
Service honda website, you have to split the cases
  • Honda Mechanic
Posted January 19, 2009 - 03:44 AM
We've changed dozens & dozens hydrostatic units since 2001 , it's approx. a 10 hour job .. Honda Canada was helping the owners out on either parts or labour or both but they now unless it's in the 2005 or newer your pretty much on your own..
  • HUSKYRIDER360
Posted January 19, 2009 - 08:45 AM
Here's a thread about the one i had, been a couple of years ago and i forgot how it acted, but its all here
http://www.paatving....hl=rubicon&st=0
  • Sandflea1977
Posted January 28, 2009 - 10:26 AM
:worthy: HOLY :bonk:!! those Hondamatics are expensive, the one one i found is on Bike Bandit for $1288.16 :banana::bonk::lol::banana::bonk::lol:, Is this a normal price? is there anywhere cheaper? if this is so i think my Rubicon is finished!:banana:, my local shop charges $98 per hour, how hard is it really to change these:excuseme:, can it be done at home?, i'm pretty good at spinning wrenches, but this has got me rattled! :bonk: never thought that would happen, what do ya think guys?
  • HUSKYRIDER360
Posted January 28, 2009 - 02:07 PM
Check with service honda website, they were the cheapest when i needed one. i put it in myself, alot of work but if you do your own engine work/rebuilding, you can do it. The price is high ,And the ones parting out on ebay and other sites is usually becouse of the failed unit. They updated these units several times since 01, so if you buy new it will be the superseded part number.
whats your location ? maybe someone on here can take the job on for you.
  • trxmaster88
Posted January 29, 2009 - 09:31 PM
anything can be done with a service manual buy one its worth it
Honda
400ex starter clutch by LukeSand
ATV/UTV   Make/Model Specific   Sport ATV
  • 2 replies
Honda
TRX400EX Burning Oil After Cam Chain Replacement by pasabre
  • 0 replies
Honda Announces More 2017 ATVs by Bryan Bosch
ATV/UTV   General ATV/UTV Forums   General ATV/UTV Discussion
  • 0 replies
Honda
Which nerf bars do people run on the trx400x by dan01cr250
Honda
400ex went through a Flood by Austin_400ex
  • 2 replies
