Is the GT thunder springs & linkage worth the$$$
8 replies to this topic
  • BB485
Posted 15 December 2008 - 09:39 AM
I have a 2006 trx 450 with hrc kit. The stock suspension has worked ok but the rear end is quiet bouncy.
  • redzoomer
Posted 15 December 2008 - 04:19 PM
Yes it is worth every dime. I have it on my 400ex and I don't know how I rode and raced without it. It smooths out whoops, dips and ruts like you would'nt believe.
  • lilbro
Posted 15 December 2008 - 04:58 PM
That is my next mod!
I am going to do the double springs, re-valve, extended travel up front and the rear with the link.
  • BEN_450X
Posted 21 December 2008 - 07:49 PM
Have you done much adjustment with the rebound settings?  I would take out a little if it keeps trying to buck you off.
  • lilbro
Posted 22 December 2008 - 08:22 AM
It sounds like your spring is a touch tight. Also increase the rebound resistance. Do these at different times so you can feel what the difference is. Your compression might be tight too. Does it buck as your hitting a bump or after?
  • sapper23
Posted 31 March 2009 - 07:37 PM
I have an '06 with GT link and GT revalve. It works great, I have no complaints about it at all. super plush and forgiving if you case a jump or flat land.
My buddie has an '07 with all stock suspension. he has holeshot 20" front and 18" rear. I have to say that the tires make enough difference that if I had rode a stock bike with 18 inch rear tires i would not have spent the extra 180 dollars. I have riddin both at the track and have to say the stock tires are the biggest problem with the honda. I dont know what honda was thinking with the tire choice, but the single best mod to make to a 450R is TIRES.
  • dirtdevil96
Posted 26 February 2012 - 06:17 AM
How was their turnaround time?I'm thinking about doing this during or after I get my engine work done.
  • ixcr242
Posted 08 November 2012 - 06:57 AM
I would go with a ARS-FX or Derisi Racing set up
  • f800strider
Posted 09 November 2012 - 07:11 AM
A suspension upgrade to include new springs and revalving to match your riding skill level and the terrain you ride is the single most important modification you can make to your quad, whether you ride recreationally or in sanctioned events.  More horsepower is not going to get you through the whoops or corners any quicker.
