Suzuki
Hot do I clean Carb on 04 LTZ400
4 replies to this topic
  • DerekC
Posted February 07, 2008 - 07:31 PM
Was running great very low hours but sat for a while and now back fires and sputters when I open up throttle.
Do not have manual
I see lots of posts on the web to clean the carb but not sure how? Take the bottom bowl off maybe? How complicated/easy is it to remove the carb?
What I have done-
Drained the fuel in carb overboard with the littel screw at bottom
Fresh gas in the tank
Checked the air fileter looks great
I found what looks to be the spark pug burried in the middle of the head but not sure how to get it out. It's tight in there.
Not sure how to get the plastics off
Does anyone know where any pictures or directions are on the web?
Thanks
  • DerekC
Posted February 08, 2008 - 12:29 PM
Got a manual now:applause:
How am I supposed to remove the plastic rivets that hold he plastic on?:bonk:
  • xkmail
Posted February 08, 2008 - 06:09 PM
Ok Newbie, let me go over the basics.
To get the rivets out take a small phillips screwdriver and gently press in the center, it will push in and then the rivet will release, too hard you will break it.
In your toolkit that came with the bike is a plug socket and 17mm? wrench.
Use those to take the plug out, gap a new plug to specs, do not over torque.
The gas tank has a few 10 or 11mm bolts that makes life easier.
Disconnect the fuel line to the petcock while smoking a j, just kidding.
Do not break the petcock (no jokes here beavis and butthead) when putting the tank back in.
To remove the carb remove the tank and side plastics.
Take it to a good shop and have them rebuild it.
When reinstalling be careful of vacuum leaks from not lining up the carb rubber boot tabs on top.
Chances are you just fouled a plug or have bad gas.
Possibly dirt in carb from loose air filter or bad gas.
Good Luck
Kevin
PS> Usually cheaper to just go to the dealer and have them do the service with oil, filter, plug, valve adjustment, then move into carb rebuild if still not running right.
  • cataway
Posted February 08, 2008 - 06:29 PM
Do not have manual
What I have done-
Thanks
did you by chance remove the air box lid ?
  • QuadRacer4u2nv
Posted February 17, 2008 - 08:50 PM
Do not have manual
What I have done-
Thanks
You clean it the same way that you would clean any other carb
Suzuki
1987 Quadracer rear shock question? by Rancher420
ATV/UTV   Make/Model Specific   Sport ATV
Suzuki
Winch for Sport Quad? by deeman
  • 2 replies
Suzuki
LTZ 250 Problems by CrSteel
  • 9 replies
Suzuki
considering buying this ltr 450 by brayd_en
  • 0 replies
Suzuki LT125 1985 by ThumperTalk
Suzuki LT125 Suzuki LT125 1985, Brand Suzuki
  • 0 reviews
