bayou 300 carb slide problems NEED HELP !!!!!!
Started by
kansasrider
, May 06 2007 04:19 PM
2 replies to this topic
Posted 06 May 2007 - 04:19 PM
I am kinda afraid to tear into the carbs on this atv but i think i narrowed down my problem to the slide not opening at WOT. when i open the throttle the slide doesnt move a single inch. if i manually move the slide a little my throttle revs to where it should be....my slide moves freely with my finger pushing it up and down. but why wont it move when i apply throttle ???????????????????????????????????
Posted 08 May 2007 - 06:38 AM
Not trying to insult your intelligence or minimize your knowledge, but:
Don't know if you understand how CV carburetors work or not; if not, there's PLENTY of great instructional material on the web . . .
"Vacuum," or pressure differential, raises the slide on CV carburetors . . . the throttle only controls an air butterfly admitting air to the intake venturi . . . the slide will not rise unless the engine is running, air is flowing through the carubretor, and a "vacuum" (pressure differential) exists above the diaphragm . . .
If you have an air leak in your diaphragm (e.g., tear or puncture), or if you do not have the diaphragm sealed EXACTLY in its groove at the top of the carburetor, the slide will not rise properly, the needle and main jet will not be uncovered as the throttle opens, and . . . running will be miserable.
Posted 16 April 2012 - 10:47 AM
Having same exact problem. No holes or tears in mine and is seated properly.. Made sure.. But mine doesnt have the vacume hose.. We're does this hose come from? When I got it the carb was off
Kawasaki KFX50 (2004) |
Kawasaki
2012 Brute force 750 4x4iATV/UTV → Make/Model Specific → Utility ATV |
Kawasaki KXT250 Tecate 1987Kawasaki KXT250 Tecate 1987 |
Kawasaki KXT250 Tecate 1986Kawasaki KXT250 Tecate 1986 |
Kawasaki KXT250 Tecate 1985Kawasaki KXT250 Tecate 1985 |
