Yamaha
how do I get my 660 raptor into reverse?
4 replies to this topic
  • towdoctor
Posted February 09, 2007 - 06:09 AM
I just picked up a 2003 660 raptor, and I can't find reverse. The tabs on the reverse switch appear to be broken. Is there a way I can find reverse with the switch broken like this? I want to check to see if I need to just replace the switch, or if my problem is bigger than just that.
  • OregonTrail
Posted February 09, 2007 - 08:06 AM
I don't use mine much, but if I recall; put in neutral, pull the clucth in, turn knob clockwise, shift down. :bonk: Like I said, it's been a while, hope this helps. :bonk:
  • love2ride450
Posted February 09, 2007 - 01:01 PM
I believe it is: pull in clutch, put in first gear, turn knob clockwise, click shifter down once more for reverse. when you want out of reverse, just pull clutch and click up once. you will be in first. Isn't the knob just attached to a cable? if the knob is broken, you should be able to replace it, but it will be the whole mechanism that bolts to the front fender.
  • nzed
Posted February 09, 2007 - 08:31 PM
yes, you are correct. that's all it'l be. it'l pay to replace the whole reverse knob mechanism. good luck!
  • YamahaBlue22
Posted February 12, 2007 - 01:01 PM
Yea, they got the right way....
>>If your knob is broken and u still want to use reverse to make sure it is ok, there is a metal lever coming out underneath the crank case, right in front of the left foot peg. If you push that lever foward with the clutch puled in in first gear you should be able the shift down into reverse..
Went to Vegas SX, met Chad Reed by CSAR FE
  • Hot  150 replies
Yamaha
2008 YFZ450 Oil Tank Does Not Drain Back by Raptorforme93
ATV/UTV   Make/Model Specific   Sport ATV
  • 4 replies
Yamaha
2001 - 2005 Big Bear lowing fuses by GEOF
ATV/UTV   Make/Model Specific   Utility ATV
Yamaha
YFZ 450 guide by Grant_5oh
  • 0 replies
Yamaha
Yfz 450 Noise by cpenrose
  • 5 replies
