Honda
'06 TRX 450 idle problems
8 replies to this topic
  • jbird710
Posted January 06, 2007 - 01:29 PM
I have a friend who has a '06 TRX 450 and he says he can't get it to idle properly. The quad is completely stock and keep in mind he's not mechanically inclined. From his description, it almost sounds like the bike is too lean as he says it will idle fine with the choke on. Sounds to me like either the pilot circuit is clogged or it needs the next size jet. I haven't worked on one of these so I was hoping to get some info from someone who has.
1.) Has anyone esle had a problem with the stock configuration being too lean or idle issues? This quad is completely stock.
2.) Does anyone know what the stock size pilot and main jets are?
Thanks in advance for any help.
  • hoblick440ex
Posted January 06, 2007 - 04:48 PM
i have 2 friends with them that have similar problems.
seems to be a common problem with them.
my one friend has an 04, and the cam broke in his. wasnt getting oil to the top of the motor. ****ed the cam up. flat spots on it. and also ****ed the rocker up. the needle bearing was ovaled. he bought an HRC kit and a new rocker assembly. and rode it a while. now it wont stay running.
my other friend has an 06 wiht idle issues and its stock.
  • mordini2005
Posted January 07, 2007 - 04:40 PM
i had a similiar problem with my 06 trx 450r it sat about a month and i started it once the whole time. changed the gas and it would only idle with the choke on . someone said to clean the pilot jet and it worked perfectly hope that helps
  • jbird710
Posted January 07, 2007 - 05:33 PM
This is what I'm expecting more than anything. The quad doesn't get used much and, knowing him, he's probably running the cheapest gas he can find in it. Thanks.
  • AEGixxer
Posted January 09, 2007 - 11:25 PM
try to richen the fuel screw a little maybe an eighth of a turn an see what that does. honda has to ship the quads lean from the fatory in order to pass all the stupid emission laws that the us and ca have put in place. one size up ont the pilot might help too
  • jbird710
Posted January 10, 2007 - 07:29 AM
You would happen to know what the stock pilot size is would you?
Thanks
  • garandman
Posted January 10, 2007 - 08:03 AM
[COLOR="Red"]I have a friend [/COLOR]who has a '06 TRX 450 and he says he can't get it to idle properly.
First off, admit that its YOU that has the quad.
Its the first step to a solution.
:bonk:
  • Fred823B
Posted January 10, 2007 - 09:45 AM
Probably the best advice here.
The stock pilot is probably a 42.
  • jbird710
Posted January 10, 2007 - 12:19 PM
:bonk:
Actually, no, it does belong to a friend and, even though I prefer two wheels, I'm not a quad hater/basher. I'm trying to get him out riding more and he always comes up with excuses; this one is something I can do something about.:bonk:
Honda
250ex Rear Hubs by mra5p7
ATV/UTV   Make/Model Specific   Sport ATV
  • 0 replies
Honda
TRX 250X died on trail then worked again by Old_Rider
  • 3 replies
Honda
Honda Introduces Pioneer 1000 Limited Edition (LE) Models with I-4WD by Bryan Bosch
ATV/UTV   Make/Model Specific   UTV / Side x Side
  • 0 replies
Honda is going to be back in the 2 stroke business in 2018 by cjjeepercreeper
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  98 replies
M10 bolt I can steal from my 450r? by cdf450
Dirt Bike   Make / Model Specific   Honda   CRF450R/RX
  • Hot  39 replies
