? Best way to plug hole left when odometer rem
8 replies to this topic
  • timvv51
Posted April 17, 2003 - 08:13 AM
I have little need for the odometer on my WR450 as am running a computer. Any suggestions on what is the best way to plug the hole in the spindle or is there a plug someone sells? Thanks for any suggestions. Tim
  • SMD
Posted April 17, 2003 - 08:47 AM
Tim remove the odo drive unit completely. Pick up a YZ spacer and seal.Much cleaner and save yourself a half a pound. :)
  • ddialogue
Posted April 17, 2003 - 08:52 AM
Is the YZ spacer and seal OEM or Aftermarket?
  • Motorod
Posted April 17, 2003 - 09:17 AM
I took my cable off. Could not find a 12mm cap nut, so I got a small standard capnut drilled and taped to fit the place where the cable attached. :)
  • Jonesy920
Posted April 17, 2003 - 10:28 AM
Flatland racing sells them.. I called last week and they said it should be out soon for the 03'
  • timvv51
Posted April 17, 2003 - 02:00 PM
I really appreciate the info. Tim
  • mmbasa
Posted April 17, 2003 - 06:08 PM
:) Go to Home Depot and by a rubber cap, should cost you about 20cents if that and just stick it over the hole. Don't waste your money on an $25 spacer.
  • Fugazi
Posted April 17, 2003 - 06:29 PM
I put a rubber valve cap on mine, fit perfect.......Just stole one off my moms car. :)
  • oRGie
Posted April 18, 2003 - 07:20 AM
and I just took the nut of the cable and glued a piece of plastic inside it to seal it.. :-)
