WR450 top speed?
57 replies to this topic
  • Zerbabilon
Posted April 16, 2003 - 02:33 PM
What is it? Can it maintain 70mph on the highway and hit 80mph?
  • Zerbabilon
Posted April 16, 2003 - 04:45 PM
C'mon.. no one with a speedo hit WOT?
  • kev426
Posted April 16, 2003 - 05:36 PM
my o1 wr426 hit 89mph stock everything with baffel removed. i think the 450 would do better?
kevin :)
  • Indy_WR450
Posted April 16, 2003 - 05:42 PM
I have hit 88 mph as indicated by my Panoram computer WFO in 5th. I have 14/50 gearing. Accuracy is probably +/- 5%.
  • Desracer
Posted April 16, 2003 - 07:44 PM
Use a GPS they make it easy. My 02 Wr250f would go 84 mph with the stock gearing, so a 450....when I get mine I will let you know.
  • Dan_Lorenze
Posted April 16, 2003 - 10:52 PM
My 01 would do 89mph with a 15 counter... I'm sure my 450's good for that if not a little more...
  • ddialogue
Posted April 17, 2003 - 02:27 AM
I clocked mine with a gps at 84mph with the stock gearing. It was on a dirt road though and the rear end was skating back and forth. I bet on the pavement it could hit 90mph. :)
  • jim-in-so-ore
Posted April 17, 2003 - 03:37 AM
I've had my WR450 up to 80 and I backed out of it because I was on gravel and there was a corner coming up, plus the PUCKER factor was starting to get my attention. That was with my analog speedo for a XT 350 that I installed rather than the odometer. It will probably maintain 70 but the engine would really be singing.
Jim
  • Dog58
Posted April 17, 2003 - 04:40 AM
My WF450 is street legal and I've had it on the interstate at an indicated 88 mph on the panoram with it feeling like there was a little more left. It is quite happy commuting at 70+ mph on the interstate with stock gearing. Plus, on the street I'm getting about 43 mpg.
  • wr250rr
Posted April 17, 2003 - 04:56 AM
All I know is its FASTER than a YZ :)
  • David_Gronlund
Posted April 17, 2003 - 05:25 AM
Well I was down in Mexico (Rocky Point) last weekend and I was drag racing with another WR450 down a flat straight road and we were hitting a top speed of 99.7mph according to his digital speedo. We were both running 15-48 gearing with uncorked stock exhaust, air holes in airbox, and richer jetting including the YZ450 needle.
  • Dan_Lorenze
Posted April 17, 2003 - 06:01 AM
Sounds about right! :)
  • Paul_in_Wa
Posted April 17, 2003 - 07:37 AM
A buddy road raced his WR450 last weekend, hit 114 at the end of the straight. Think 15/43 was his gearing, and he was on 17's.
Paul
  • Indy_WR450
Posted April 17, 2003 - 09:06 AM
Sound like a Super Motard set up to reach 114 mph? Knobbies would slow him down considerably! :)
  • SBG
Posted April 17, 2003 - 09:56 AM
If it was geared for speed, it would probably be capable of at least 115mph. I had an XT350 that would pull @95+ on the flat, and with a back draft and slight hill, it was doing 105 with a passenger. I know the wr250 and 450 have to have more power than my old XT. My DR650S also could crawl its way up to 116 before I shut it down, and I'd guess that the wr450 would be a little stronger than my 650. I just don't know where the torque figures are. Dirtbike mag did a comparison between a CR500 and VFR back in 85 I believe, and the CR walked away every time. I forget what the mph's were, but dirt bikes can hit the 100+ barrier. They also did speed tests on a dry lake and were coming in @ 120mph. Not bad, but that was regeared and they made a mini fairing for it.
  • Jonesy920
Posted April 17, 2003 - 10:25 AM
88 MPH You didn't go "Back in time" did you ? Hope you had the flux capacitor turned off.... :D :D :)
  • Zerbabilon
Posted April 17, 2003 - 11:02 AM
Awsome 80mph is the fastest I'd need to go.
The Jeep only tops off at 85mph before it gets too scary dangerous. Its either a WR450 or a YZF R6.
  • r1superstar
Posted April 17, 2003 - 05:21 PM
What does this have to do with anything??
  • Zerbabilon
Posted April 17, 2003 - 07:34 PM
I asked the top speed to make sure it could handle the highway. I don't know if I want a YZF R6 or WR450 dualsport... My main vehicle is a Jeep and the a WR450 can go faster then I can go now and I didn't think it would be able to and the Jeep goes as fast as I need to go. 80 mph
Posted Image Posted Image
  • Lon13
Posted April 23, 2003 - 12:46 PM
The fastest I've had mine is about 160mph. No wait, that was my R1. Ahhh, I think my WR will go about 120, since it is a little slower than my R1. :)
