Wiring for Vapor Indicator Dashboard
4 replies to this topic
  • fatcrackers
Posted October 14, 2009 - 05:11 PM
I've seen a few other riders on the forum have also installed the Trail Tech Vapor speedo/tacho... but has anyone had any experience with the additional indicator dashboard (http://www.trailtech.net/022-PDA.html)? I've setup the Vapor on my 2005 WR450 and am about to have a crack at wiring up the 4 lights on the dashboard. I'm probably going to go with left indicator, right indicator, high beam and power (key is turned to "on"). I can probably work out which wires I need to connect up without too much trouble but thought I'd see if anyone else has already done this. Any tips or photo's would be really appreciated. Cheers.
  • fatcrackers
Posted October 20, 2009 - 03:23 PM
Ok, nevermind... after having a look and connecting up the wires I realised how ridiculously easy this really is. I probably should have put some thought into what is involved before posting this thread. Cheers.
  • bakeyz426f
Posted October 20, 2009 - 05:04 PM
i bought a vapor computer for my wr426f and was wondering if can wire it up some how to make the lights stay on at night.
  • William1
Posted October 20, 2009 - 05:15 PM
Connect the power to the bike battery. No need to switch the Vapor off. 15 minutes of inactivity and it turns itself off.
  • bakeyz426f
Posted October 20, 2009 - 05:23 PM
my wr426f doesnt have a battery. its powered by the stator. i thought i saw some where you could tap into a wire like the cdi to get power. im also adding a small 8 aa batery pack to run a horn and turn signals so i thought about tapping into that to power it.
