JS's works shock
7 replies to this topic
  • surfer-b
Posted October 14, 2009 - 12:01 PM
Check out the works shock preload ring, I havn't seen any photos of the stock shock but wonder if its the same. Its the 2nd photo in the MXA mid week report about his bike. http://www.motocross...9D8BA828CF074DE
  • huffster
Posted October 14, 2009 - 12:07 PM
Yeah, I'm sure if you have $ 5k worth of chump change laying around...The ring is included with the SHOCK !
  • Ga426owner
Posted October 14, 2009 - 12:26 PM
I totally agree!
I do not expect the stock 2010 to have anything remotely similar to JS's KYB front or rear suspenders. It may look similar but it won't be....look at Ti rear spring,(what it should have come with IMHO instead of the cheap steel spring) I assume the front springs are also probably Ti internals are all works KYB..., the front fork coating and the top caps with what looks like allenhead comp adj nuts......about as trick as it comes
  • harrperf
Posted October 14, 2009 - 09:03 PM
My supplier makes and sells ti fork springs...but will rarely sell to "public". I asked why...and it turns out the rubbing that occurs inside the forks wears out the ti springs in a very short time warranting frequent replacement.
They told me 10 hours was pushing it! One customer is very wealthy...and can afford it...but when I told him that...he said hell no from a pain in his rear standpoint of swapping them out all the time!
Just a little something I learned...figured I pass it on. I wonder just how long his team has had the bike to work on it!
  • Aka.Goose
Posted October 14, 2009 - 09:11 PM
I love how his rear extra reservoir has an extra reservoir...
Posted October 15, 2009 - 07:00 AM
The thought of a significant amount of ground titanium floating around inside the fork is a bit unpleasant, too, no?
Based on things JS has said, I think they've had it between 6 months to a year so far.
  • harrperf
Posted October 15, 2009 - 07:51 PM
certainly not!
Good thing factories can service it often!
Interesting question...and I don't really care either way for answer...but it may also be why the twin chamber is still in use with (mostly) separate oils for primary valving....
Let's hope he has it more dialed than last year to start the season!
  • rickallen124
Posted October 15, 2009 - 09:08 PM
I think James said that the first time he got to ride it was back in May after the Vegas sx and then he got a bike to ride at his house about 6 weeks ago. He talked about it in one of the interviews and he said that they were ahead of last year from the start because the new bike is so much better. I'd have to check the interview to know exactly how long they have been testing.
  • 5 replies
  • Hot  47 replies
  • 0 replies
  • Hot  36 replies
