YZ426 Jetting
3 replies to this topic
  • James_Dean
Posted May 27, 2000 - 08:10 AM
What jetting setup works best in the YZ426? It has changed alot from the YZ400. Can it be improved? Bigger main or richer clip position...
- I'm used to KX500's and am Power Hungry!!...
- Pilot, pilot screw, needle OBE--, clip, main
- Post here or in the Jetting Section on the forum.
Thanks
James Dean
  • Freewhitewolf
Posted June 02, 2000 - 08:04 PM
I have a 2000 YZF426.Regardless of altitude when i rip on the gas,my bike sputters a little bit, but low and mid range are great.does anyone else have this problem or know the fix?
Thanks
James Dean
  • Airastro
Posted June 02, 2000 - 08:36 PM
I also have a YZ 426, and am running an aftermarket pipe ( FMF). I am 1 step richer on both the main and pilot. I have played w/ the fuel screw from 1 1/2 to 3 turns out. When you rollthe throtle on it runs great, but if you rip the throtle from very low rpm, I get the stumble at at times it will evn kill it. This only happens with rpm's near idle. I am still experimenting with this last little glitch. I am riding in So Ca so the tracks are basically sea level
  • MxGuy
Posted June 03, 2000 - 08:39 AM
I just turned up the idle a bit more that way my 426 isn't quite so easy to stall when bogging through a tight situation. The higher idle gives the gear a little more power and keeps it running and also doesn't bog as much cuz the rpm's are already up a bit more. Just my oppion.. but works good for me.
Jody, Ontario, Canada
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  50 replies
  • Hot  47 replies
  • 0 replies
