Getting out spark plug?
5 replies to this topic
  • Rea666
Posted October 14, 2009 - 04:29 AM
How to get out the spark plug without original wrench? Any idea if it's possible and could you recommend what i can use? Thanks
  • byggd
Posted October 14, 2009 - 06:10 AM
I use a 5/8 plug socket with a built in universal joint and about a 6” extension
  • PBDBLUE
Posted October 14, 2009 - 06:15 AM
5/8 plug socket and a 3/8" wobble extension.
http://www.lowes.com...2894&lpage=none
  • Reedus
Posted October 14, 2009 - 01:57 PM
I used a 5/8 spark plug socket with the small extension. Loosen the plug, then pull out the extension leaving the socket and plug in the cylinder head. Then I insert my telescoping pencil magnet and fetch out the spark plug and socket
  • dustin63933
Posted October 14, 2009 - 06:43 PM
If your socket or anything ever falls in there and you can't retrieve it a good thing to do would be to blow compressed air in the weep hole.
Also you can use the sparkplug cap to retrieve the sparkplug.
Just a little bit of useless information.
  • Parx_400
Posted October 14, 2009 - 09:20 PM
Take the valve cover off. Makes it much easier.
