125cc lifan engine help
5 replies to this topic
  • rocketaj
Posted October 12, 2009 - 06:49 PM
hey i have a 125cc lifan engine. im breaking in my engine. and how much gas should i put through it before i redline it. and how often do i change the oil. i changed it every 10 hours of riding on my old bike. should i do the same. and what dose it mean my blug has white stuff on it. dose that mean im running rich. and how do i clean the oil screen. and how often... dose any one have head breathers on their bike and how dose that work. thanks. :bonk: :bonk: :bonk:
  • burtonx013
Posted October 12, 2009 - 08:33 PM
Step 1:
List bike for sale on craigslist
Step 2:
Purchase a Yamaha, Honda, Kawasaki, or Suzuki
Step 3:
Purcahse a shop manaul
Step 4:
Read Shop manual
  • Fixitguy74
Posted October 13, 2009 - 06:22 AM
Step 1:
Step 2:
Step 3:
Step 4:
Read Shop manual
Don't listen to this guy.
As for the redline question, run a full tank of gas through the bike. Start with a full warm up and half or less throttle for the first 15-20 minutes of riding. Then progressively give it more throttle in short bursts but back to half or less for cruising until the tank is empty/near empty. Lastly let it cool down, check all fluids and top off the tank. You should be good to go after that.
On the oil change subject, I would change it after 3 hours or less of ride time for the first oil change and then follow up every 10 hours. Just remember to check the oil level often.
The spark plug should have a chocolate brown color to the porcelain tip if the jetting is correct. If it is white then it is lean from incorrect jetting, an air leak, dirty carb or water in the gas. If the tip is black, sooty or wet with gas then it is rich from incorrect jetting, stuck floats or worn or damaged needle and seat.
The other questions may be better answered by someone with the same bike, so post this in the Chinese forum for better help with less haters.
  • rocketaj
Posted October 13, 2009 - 11:23 AM
thanks so much
  • Fixitguy74
Posted October 13, 2009 - 05:52 PM
thanks so much
No problem. :bonk:
  • TakeTheSafetyOff
Posted October 13, 2009 - 05:56 PM
Step 1:
Step 2:
Step 3:
Step 4:
Read Shop manual
agree 110%. :bonk:
Trouble selling bike? by Bwdeaton
Dirt Bike   Make / Model Specific   Kawasaki   KX250F
  • Hot  44 replies
KTM 300 XC-W 2017 by pat22043
KTM 300 XC-W 2017
  • Last review by pat22043
  • On September 22, 2016
Broke in a 2017 Ktm 300 today by The Anvil
  • Hot  31 replies
Yz250 throttle issue by Neilmccown
  • Hot  26 replies
Tusk Impact weight vs Excel TAKASAGO rim by RMK800
  • Hot  27 replies
