How to re-sleeve a cylinder
No replies to this topic
  • jmeperu
Posted 11 October 2009 - 05:08 PM
This was done on a 400cc single but it works on twins and 4 cyl's as well. Clean your cylinder and get as much oil out as possible and freeze your new sleeve or sleeves.
Use an oven to heat to 450 deg F
Attached Image: DSC_1718.jpg
Attached Image: DSC_1720.jpg
push cylinder down and most of the time the sleeve or sleeves will pop up
Attached Image: DSC_1722.jpg
use an oven mitt or welding glove to pull the sleeves out. if they dont pull out then gently tap them out with a large tipped punch.
Attached Image: DSC_1723.jpg
remove new sleeve from freezer and drop it in.
you will still need to have a machinist face the top of the cyl and bore it to your piston, but you saved yourself a few bucks.
