KX65 won't start, please help!
3 replies to this topic
  • ajaxv2000
Posted 11 October 2009 - 05:08 PM
Hello guys!
My son's '02 kx65 won't start. After 7-10 kicks gas is comming out. I've tried push start, but still unsuccessful. I've got spark, but I couldn't hear the explosion in the carb. What I should do?
Thank you.
  • frankiewhipit
Posted 12 October 2009 - 05:14 AM
You should never hear an explosion in the carb!
Replace the spark plug, they go bad with no explanation :thumbsup:
  • makKX250
Posted 12 October 2009 - 09:19 AM
When it is really cold I have had to bump start my son's KX65. But anything over 50 degrees it has started in 2-5 kicks when cold. Did it sit unused for a long period?
Always start troubleshooting with a new plug.
Is the new spark plug wet with fuel after trying to start it? If it is dry then look at you fuel system. (Check carb for dirt/water, plugged jets, fuel petcock screen is clean, carb vent lines/fuel tank cap vent line plugged, air leak, etc)
If the spark plug is wet check compression. Our '02 KX65 is so easy to crank over that I don't know if I would notice that it lost its ring seal. If you don't have a compression tester you can at least remove the exhaust and reed block and look at the piston to see if it seized - you will see scoring on the piston.
You said gas is coming out? If the gas is coming out the vent tubes of the carb when you turn on the gas then you need to check the float level and the float valve.
  • ajaxv2000
Posted 12 October 2009 - 11:46 AM
Thank you all.
