puvcustom said:
This 650 is an "L" and I found out that he removed the smog pump and the spark arrestor from the exhaust. At this point I'm unfamiliar with a lot of this bike. I've been looking for jet kits and I find the typical Dyna Jet kit that includes an adjustable needle jet and other kits that don't have the needle but include a slow jet. ***? can someone make sense of this for me? I know that the bike has stock jets in it with a 152 main, and i think a 58 slow jet, and a non adjustable needle. Not exactly sure what kit to buy. Maybe I don't need a needle jet. hmmmm
you will be fine with the dynojet kit, use the dynojet 165 main, carb spring and get a 55 pilot from a honda dealer and or jetsrus dot com, grind off the adjusting prevention tab on the air fuel screw then turn it in until it seats and run it back out 2 1/4 turns. Toss the stock filter - tell him to go get a UNI filter for it. If it is sound he wants along with performance get a
FMF powercore. Way better performnace than a hacked on stock pipe. This will return the XRL to a good running bike.
as for his HD. Power commander from fuelmotousa and a set of vance and hines pipes and install. Power commander comes premapped and is a brainless installtion. as are the pipes. however so many HD riders take it to the stealer to have this done and get raped. But! they get to walk around in chaps and grunt at each other....:lol:
