1997 XR650L said:
Its getting colder here in Denver and it takes a long time to start my xr650l. I mean I almost drain my battery every time. Do my valves need to be adjusted? I have 11k on the clock and I dont know if the PO has adjusted them before.
Valves are "fairly" easy to check.
Quote
Or- are they just hard to start when cold?
Shouldn't be that hard to start. Fuel formulation (ethanol) or the oil viscosity could be a factor with hard starting at low temps.
Quote
if its the valves, how hard are they to adjust? I can change oil and plugs, thats the extent of my mechanic knowledge
Get a Honda Factory Service or other quality service
manual first, get the right tools & then you could consider attempting to adjust the valve lash or gap, if they are out of spec.
Quote
~on a side note, I have 20-50 synthetic oil in it, is this too thick? also, I hear a winding or something by my right foot when I start it until I crack it one and it seems to lube it self up~
I don't live in a freezing climate but this could be an issue if the engine is really straining to turn over, let alone start. I run 15W-50 full synth in mine all year but my XRL gets to sleep in a comfy garage when parked...
Keep Ridin'
D_D
"It can't be the rider, it's gotta be the bike. Yeah, that's it..."
