Spark Plug
23 replies to this topic
  • Honda-Rider420
Posted October 06, 2009 - 06:21 PM
This may be a stupid question but does anyone know what size the spark plug is?
  • Pr1malR8gw
Posted October 06, 2009 - 06:40 PM
its not a stupid question as my manual does not list the exact one..
I believe its a c8eb but I will find out hold on
  • Pr1malR8gw
Posted October 06, 2009 - 06:42 PM
sorry cr8e
  • Pr1malR8gw
Posted October 06, 2009 - 06:43 PM
how ever if its an 05-04 its just a cr8 plug
on my 07 i'm running a cr8eix plug thats the irridium one seems to idle a bit smoother.
  • chasemotox63
Posted October 06, 2009 - 06:48 PM
my 06 manual also lists a cr9e as an option if the 8 is to hot.
  • Honda-Rider420
Posted October 07, 2009 - 09:55 AM
i mean what size socket is it?
  • Pr1malR8gw
Posted October 07, 2009 - 11:21 AM
It's standard 9-16ths maybe. Can't remeber
  • D-K
Posted October 07, 2009 - 11:37 AM
I believe it´s a 16mm socket.
  • ForsheeMS
Posted October 08, 2009 - 08:22 AM
It's a 5/8 socket
  • D-K
Posted October 08, 2009 - 09:02 AM
Ok, to clear this up I went to NGK´s site and this is the spec for a CR8E:
C = 10mm thread and 16mm hex grip
R = Resistor
8 = heat range
E = thread reach 19mm
There you have it.
http://www.ngk.se/up...ckning sid2.pdf
A 5/8 socket works, but is not what it´s made for. But maybe it gets the job done. 0.625 inch = 15.875 millimeter
  • ForsheeMS
Posted October 08, 2009 - 09:14 AM
That's funny. My NGK catalog says it's:
10mm thread
3/4" reach
5/8" hex
I guess if you're here in the states you would use a 5/8" socket. Countries in the metric system would use a 16mm socket.
  • D-K
Posted October 08, 2009 - 09:43 AM
10mm thread
3/4" reach
5/8" hex
I don´t get it why you mix between inches and mm´s. You should switch to the metric system and skip the fractions:lol:
The reach and hex can be measured in inches, but the thread is metric, so it just gets confused, hehe.
  • ForsheeMS
Posted October 08, 2009 - 11:14 AM
We're Americans and feel the need to be a little bit different.:busted: All of my measuring tools (calipers, micrometers, dial indicators) measure in inches.
  • Pr1malR8gw
Posted October 08, 2009 - 03:35 PM
Haha. I use only metric. Except for a sparkplug wrench.
I love metric when dealing on small scale. How ever when dealing with speed distance and height inches feet and miles is better.
Same thing with temprature farenheight kicks celsious ass
how ever if celcious was not based on water it would be fine.
Ohh and British thermo Units rock also. Haha
  • D-K
Posted October 09, 2009 - 12:01 AM
Haha, what´s wrong with basing it on water´s properties?
That is a real and useful thing.
What is 0 degrees Fahrenheit based on?
  • Pr1malR8gw
Posted October 09, 2009 - 06:53 AM
Because water is not a good base line IMHO
  • D-K
Posted October 09, 2009 - 11:07 AM
You didn´t answer my Q?
Edit; haha, I read up on it on Wiki, and I still don´t get it. Now I know why you didn´t answer, there is no possible way of really knowing. Haha, you just use it. haha
  • Pr1malR8gw
Posted October 09, 2009 - 12:35 PM
I do belive it's based on mercury and the height it rises.
My main complaint with celcious is actuly just does have enough space. 100 points is to small when comparing a vast amount of space between freezing and boiling. Maybe if it was 0 to 1000 or killecious would be a more apt mesurement then 100 but a
  • D-K
Posted October 09, 2009 - 01:09 PM
wiki said it was based upon the coldest thing that could be artificially made at the time, 0 degrees F. And then the human bodys core temp.
Only problem they couldn´t measure the core temp exactly, and were off by 2.5 degrees. Haha...
And for the record, Celsius doesn´t stop at 100 degrees. Haha, it has no upper limit because it can be infinately hot.
For example, steel turns red at roughly 800 degrees C.
:bonk: :bonk:
  • Pr1malR8gw
Posted October 09, 2009 - 02:46 PM
MI'M not saying it doesn't stop at 100. It's just to condenced.
I guess that would be fine when meauring heat in a scale used for metals.
How ever for human exsistance especialy when relating to weather and cooking there is not enough space.
Yeah your comback is. Well you can get beyond the decimal point. But it's to hard to understand. 32.008 vs 32.8
with farenheight 32 and 32.5 means minimal. How ever on the celcious scale it means a substantial diffeance.
I grew up with farenheight it's much easier to grasp.
I also grew up with inches and feet used in construction and I hate it. That's where metric rocks. How ever human height weight speed and traveling distance is easier in feet miles and miles per hour.
When working on mechincal stuff. Metric is better and I hate standard.
So that's my feelings. They won't change.
2 stroke enduros by 2010crf
  • Hot  82 replies
14 250f FMF issue by zycki251
Dirt Bike   Make / Model Specific   Yamaha   WR/YZ 250F
  • Hot  33 replies
KX250F Performance / Complete Rebuild by bratnetwork
Dirt Bike   Make / Model Specific   Kawasaki   KX250F
  • Hot  33 replies
Do most 4 stroke dirtbikes not feel smooth? by Ripping_RobMX
  • Hot  28 replies
building a kx250f by Kawasaki250f
  • 4 replies
