YZ426F Help
3 replies to this topic
  • gordster1122
Posted October 06, 2009 - 01:13 PM
today i got the engine out and now i got the swingarm left and the front end now today i got the nut off so i can take the triple clamp out if thats what it's called how do i get it to slide out of the frame now??
  • cowboyona426
Posted October 06, 2009 - 01:44 PM
Remove the nut on top of the upper triple clamp, loosen the pinch bolts and slide the upper clamp off. Now loosen the spanner nut and the rest of the works will slide out.
  • gordster1122
Posted October 06, 2009 - 02:42 PM
k i just got the top triple clamp off is there a special tool you have to use the get it loose?
  • cowboyona426
Posted October 06, 2009 - 03:51 PM
No, you can use a screwdriver and a hammer to loosen it if needed. They do make a special tool that makes it super easy though, called a spanner wrench. I bought a set of 3-4 from Harbor Freight a few years back for like $10.
  • 0 replies
  • Hot  79 replies
  • 5 replies
  • Hot  36 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
