Pull arm to do buffer?
4 replies to this topic
  • Guest_Guest_*
Posted April 13, 2003 - 11:56 AM
Time to change the chain buffer on my 99 WR, this will be the first. Do you have to remove the swing arm to replace the buffer? I did a search and couldn't find a answer..
Thanks Domenic :D
Never mind I found the information :)
  • ddialogue
Posted April 13, 2003 - 04:18 PM
I would think so. It just doesn't seem like there's enough room between the countershaft sprocket and the swingarm to pull it around.
  • WR_Jason
Posted April 14, 2003 - 09:38 AM
Yeah, so whats the answer?
  • MOmilkman
Posted April 14, 2003 - 04:37 PM
Ive replaced the stock chain buffer (no, you do not have to remove the swingarm) and I have put a TM designs buffer on. (yes, you do have to remove the swingarm)
  • Guest_Guest_*
Posted April 14, 2003 - 05:19 PM
The answer is both, I'll pull the swing arm and service the bearings at the same time, I never had this much maintenance on my 2 stroke :)
