XR-XRL Engine/Frame swap
2 replies to this topic
  • jcshew
Posted 06 October 2009 - 09:10 AM
Hi,
Anyone know if an XR650L engine (94-current) would be a direct fit into a 93 XR600R frame?
Thanks
  • cleonard
Posted 06 October 2009 - 09:44 AM
It is my understanding that it will be a direct fit.
There is a bit of an electrical concern. To run the XR600 electrics you will need to swap out the XR650L stator with an XR600 stator. The 600 stator has the magneto winding for the CDI where the L stator is only wound for 12 volts.
  • HeadTrauma
Posted 06 October 2009 - 03:47 PM
Mechanically, yes, it will fit. Like cleonard said, the 600R ignition is configured to run on its own dedicated high voltage AC stator windings. The 650L's ignition uses regulated 12v DC from the main charging supply. Assuming you still have it, just put the 600 stator in the 650L engine.
