pilot screw adjustment
1 reply to this topic
  • ThumperWR450F
Posted April 13, 2003 - 06:31 AM
how do you know when your pilot screw is adjusted correctly?i saw a post before about it but when i did a search i didn't find what i was looking for so i decided to post about it again. i have a 165 mj 48 pj 72 sj i didn't touch the needle. i am at 2 turns out right now. i blip the throttle and it revs high than goes down to a steady idle. does not drop to a bogging idle. so am i good ? seems to be ok to me but i figured a second or third oppinion would ease my conscience.
  • Indy_WR450
Posted April 13, 2003 - 05:10 PM
Between 1 and 3 turns is the normal range. You will have to change your pilot jet if you exceed this range. Somone posted a chart for fuel screw position and pilot jet relationship. If it works well at 2 turns I think you are OK. :)
